93 f150 losses prime when it sit any amount of time?
I was given this truck when my grandmaother passed away it has 45,800 original miles on it, it has sat a little, when you let the pump prime up it will start and runs great once the fuel pressure builds up .what may be causing it to loose pressure?
That's normal. The fuel pump should run for 2 to 5 second to build pressure in the fuel rails, then it will start and run just fine. The fuel pressure regulator open and closes to let fuel return to the fuel tank so the injectors receive the proper amount of fuel. As the truck sits it loses vacuum and the regulator opens up letting the fuel flow back to the tanks. If the pump is running longer than a few seconds before it's building pressure you may have a bad/weak fuel pump.
Shawn Paris
08-02-2016 10:56 PM
Brickster68
04-10-2013 03:57 PM
DJdemon6696
27
12-02-2007 04:43 PM
