You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
i am having trouble finding some parts for my 59 f100 transmission and was hopeing some one could point me in the right direction.. it is the stock 3 speed manual light duty transmission.
I will have a complete stock 3 speed from a 60 along with clutch, etc available in a couple weeks. A guy is buying the motor and doesn't need the transmission. Everything is installed and running now. After the engine sells I have a drivetrain transplant planned.
Anyway - If you want a complete working one instead of rebuilding your current let me know. Location is in MO so shipping might be more of an issue than something closer to you.
Im needing a countershaft and also the low and reverse gear as well as the bushing and shaft for the reverse idler gear. Napa has the bearings and gaskets.
Im needing a countershaft and also the low and reverse gear as well as the bushing (only available with the gear) and shaft for the reverse idler gear.
Napa has the bearings and gaskets. What about the front/rear seals?
Please, when asking questions, list all the pertinent info. 223 or 292? Short or long wheelbase?
There are 3 different low/reverse gears, specific either to 223 or 292. Count the number of helical teeth, will be either 23, 28 or 32.
