green and red lines to turbo/intake tube
Yeah you can remove the entire wastegate solenoid and all. Red pressure line from below the solenoid tee's with red line and go to actuator, the excess comes back to the solenoid in the red line to the wastegate actuator which is what regulates the amount of pressure applied to the actuator by bleeding excess pressure off and dumping into the intake.
You can remove all of those components, just a soft code. 470ohm resistor would take care of that though.
on
Plugging the red line from the WG solenoid to the WG actuator will net higher boost. The WG actuator starts bleeding off boost at ~ 5psi. On a stock turbo, benefits can be had by tightening (shortening) the WG rod. This creates allows moost boost to build before opening and still allows computer control with the red line connected. High boost is hard on the journal bearings and shortens the life of the turbo. You can remove the WG solenoid, as mentioned above, and install a strictly mechanically controlled WG controller, i.e. the Turbo Master WG Controller, which is easily adjusted to limit the high end of the boost and give better results across the rpm range. I chose to use the Turbo Master on my stock turbo (with ATS compressor housing) and later added a 1.0 turbine housing. This proved to be a very good combination for my truck.
The following users liked this post:
