1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Hauling 3 horse gooseneck with f250 v10
Old 07-04-2012, 04:43 PM
3horses4me's Avatar
3horses4me
3horses4me is offline
Looking for some suggestion.
I have a 99 f250 v10 that has been lifted with a 6 inch lift. I just purchased a 3 horse gooseneck that weighs about 6000lbs.
Hauling the trailer empty my back leaf springs were looking taxed. I am getting the parts to lower the truck but wondering what the back springs should look like with this kind of load?
There are no overloads not sure if they were removed when it was lifted or if they were never there.
Old 07-04-2012, 06:29 PM
F350-6's Avatar
F350-6
F350-6 is offline
Welcome to FTE. How bad did the springs look? Perhaps the lift springs weren't designed for towing. Or there's a possibility that it's just junk 99 springs. I had a 99 that the leaf springs seemed pathetic when brand new if you put a trailer on it.
The easy answer would be to put an overload spring on your existing to help when towing. Airbags would be another option, but more expensive.
Old 07-04-2012, 10:15 PM
ak-angler's Avatar
ak-angler
ak-angler is offline
Airbags are more expensive than springs? How cheap are new springs? I just installed new Air Lift 5000's on my 2003. It cost me part of a Saturday and $253 total. And yesterday I pulled a 12,000# trailer 160 miles. The truck was level and the ride was smooth with them pumped up to about 75 pounds. When I dropped the trailer, I let the air out of the bags and I was back to having my normal ride.
Old 07-06-2012, 11:51 AM
AirLiftCompany's Avatar
AirLiftCompany
AirLiftCompany is offline
SPONSOR
I would imagine that your springs should still have a decent amount of arch to them with that load. Is the lift all spring or is there a block under them? If it is an aftermarket spring, it might not real be intended for towing as F350-6 mentioned.
If you plan to drop it back down to factory height soon I would wait on adding anything like airbags or an overload spring. For one, a factory spring might handle the weight a lot better. Secondly, an airbag kit would require spacers to accommodate the lift, which is simply an extra expense which you wouldn't need.
Old 07-06-2012, 07:17 PM
F350-6's Avatar
F350-6
F350-6 is offline
You can get overload or helper springs for less than that, but they don't work as well as air bags.
Old 07-06-2012, 08:53 PM
TrdLtly's Avatar
TrdLtly
TrdLtly is offline
TreadLightly
I had Timbren's on my F250. They are inexpensive, handle great, easy to install. Worked great for our slide-in camper.
Vehicle Suspension Kits - Timbren Suspension Enhancement Systems
Old 07-06-2012, 09:02 PM
ak-angler's Avatar
ak-angler
Doh! For some reason I was thinking of a full spring pack, not just add-a-leafs (even though you clearly said "overload spring" in your other post).
68cabby
02-12-2017 02:11 PM
frdf250
06-05-2011 11:25 PM
Sanchez_315er
05-15-2008 01:06 PM
98greensi
01-07-2008 12:45 AM
rebelbob
06-20-2003 09:44 AM
Quick Reply: Hauling 3 horse gooseneck with f250 v10
