oil pan plug
oil pan plug
Can anyone recommend an oil pan for a 390 that has the plug located on the right rear corner, so the oil does not run all over the axle. I have a 76 F-250 4x4. I have looked at summits site. They are to deep or the plug is on the left rear corner. I would rather avoid moving/modifying the pan plug if at all possible.
Whoa...That'd be alot of work for very little return..... Get one of these with the nipple (Formerly known as a Fumoto valve): QuickOilDrainValve.com
With a 4x4, I recommend drilling the lever and safety wiring it so it doesn't inadvertently open at an inopportune (and expensive!) time.
I'm gonna be installing one on my 2WD bump cuz the stupid drain is right over the front crossmember... I'd like to punch the Ford engineer responsible for that retarded design.
kheisler
01-20-2019 03:36 PM
greghoffmann
03-24-2001 07:43 AM
