1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear end axle hub nut torque
Old 07-01-2012, 03:32 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
I have a couple of questions.
I replaced a bad leaking rear axle seal.
my book is hard to fallow on instructions
The book says to pack the bearings. docent the rear end lube them ?
Im using the old bearings. they looked good. no discolor or pits.
then it says to torque the ratchet nut to 60 Ft lbs and back off 7 clicks for used bearings.
the only thing i didn't do was pack the bearings when i pit it back together
i have not driven the truck yet. should i pack them or is it ok because there was no grease in them, only oil when i pulled them out.
and is this 60 lbs and 7 clicks back right ?
Old 07-01-2012, 06:23 PM
sand_fiend's Avatar
sand_fiend
Ok, I guess being over medicated is better than living in pain.
Pulled it apart and packed the bearings and did the 60lbs and 7 clicks back
Old 07-02-2012, 09:00 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
My manual said to put gear lube on them, I still used some grease anyway... You need to put something in there because until you drive it and make some turns, gear lube won't work it's way down into those bearings.
But yes, that sounds right - 60 ft/lbs, 7 clicks back. I would spin the hub while doing this just to make sure the bearings are fully seated.
I just did one of my rear bearing seals...
Old 05-06-2018, 07:41 PM
Choptopjimmy's Avatar
Choptopjimmy
Choptopjimmy is offline
What type of socket is required to remove the ratchet nuts? Thanks, Jim
Old 04-20-2024, 10:40 AM
Joseph cox117's Avatar
Joseph cox117
Joseph cox117 is offline
1st Gear
You need otc 7269
BadDogKuzz
01-10-2011 05:06 AM
1fastroadking
12-02-2010 04:23 PM
cookie88
22
08-11-2009 05:52 PM
Grsyhands
1997 - 2003 F150
09-21-2006 06:23 PM
MrCBofBCinTX
01-21-2005 08:37 AM
Quick Reply: Rear end axle hub nut torque
