Rear Bearings
Rear Bearings
Is there a procedure for tightining the rear axle bearings if they are not removed or replaced. Is the nut set to a given torque and then backed off or do we just take the play out and leave it. Seals are not leaking and there is no signs of failure, just a little side to side play on the tire after 125,000 miles.
Thanks
Richard
Thanks
Richard
on
Tighten the hub nut, rotating the rear hub occasionally while tightening. Tighten to 60 ft-lbs.
Adjust hub nuts as follows:
For new bearings, ratchet back five teeth or notches (1/8 turn) on the hub nut. Five notches must be felt during this operation in order to have performed it correctly.
For used bearings, ratchet back seven teeth or notches (1/6 turn) on the hub nut. Seven notches must be felt during this operation to have performed it correctly
Do you have the special socket to do this?
