Bed Wood Dimensions
Old 06-30-2012, 09:36 PM
1954_NJ_F100's Avatar
1954_NJ_F100
1954_NJ_F100 is offline
Bed Wood Dimensions
I read somewhere that the original bedwood for 1953-56 F100's was 7/8" thick. I had some long leaf southern yellow pine milled and I am cutting the edge rabbets in now.
Anyone know:
1. Was the original bedwood 7/8" thick?
2. If 7/8" was the original thickness, are the rabbets deeper than 1/16"?
Thanks
Old 06-30-2012, 10:19 PM
South of BC's Avatar
South of BC
South of BC is offline
I just went out to the shop and measured the bed wood I got prefabricated by Mid-Fifties. It's 3/4 inch thick and the rabbets are 1/8 inch deep.
Old 06-30-2012, 11:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
http://www.clubfte.com/users/earl/Re...on Information
Click on "Vehicle Dimension Information"
Should be all the bed info you need
Old 07-01-2012, 09:05 AM
South of BC
Nice link, Ross. It appears the end boards have a rabbet of 1/16 inch on the ends, I only measured a couple of center boards. Hopefully the original poster checks back as the width of the rabbets is different too.
Old 07-01-2012, 10:14 AM
1954_NJ_F100
Thanks all - I had a similar bedwood fab drawing and mistakenly read all rabbets as 1/16". I will now be re-milling the 5/8" edges to 1/8"; may try the alternate tapered rabbet on some scrap.
Old 02-22-2013, 11:02 AM
FP's Avatar
FP
FP is offline
Thanks, good info. You saved me from posting the same question.
Old 02-22-2013, 12:11 PM
Project-55's Avatar
Project-55
Project-55 is offline
When these trucks were built "as trucks" the steel ribs were designed to be higher than the bed wood, thus saving on damage and gouging of the wood.
However, it gives the bed a cleaner look when the bed strips are flushed into the bed wood, a rabbit of 1/16 inch will have the strips raised above the level of the wood, even a 1/8 inch rabbit will make them a bit high.
I suggest measureing the deck height of your bed strips (my original's are 3/16 tall) and make your rabbit suit the look that you want. When I cut the boards for Jon's 50, the stainless ribs were 1/4 inch high so thats what I made the rabbits because he wanted everything flush and smooth.
Old 02-22-2013, 12:14 PM
Project-55's Avatar
Project-55
This is kind of a PS; I bought the clear grain white oak boards for Jon's truck at lumber liquidators for less than half what the supply houses want for bed boards, You just have to do your own saw work.
Don Vito
20
06-27-2016 12:34 PM
Manjo
01-03-2005 10:19 PM
gl51ford
04-03-2004 08:55 AM
rchassie
01-23-2003 10:43 AM
mark50
03-07-2001 04:59 PM
Quick Reply: Bed Wood Dimensions
