Really odd problem
#46
Guess my truck insists on makeing a fool out of me. Got the tire gauge sitting in the console just waiting on the truck to act up. Put a good many miles on it with the untreated fuel today, even driving the fool out of it at 70-75mph on the way home. Guess what? Not even a hic-up. I know it will eventually act up, but while I can spare the time in the morning I'll go ahead and get that pressure reading and clean the screen and go from there. BTW, has anyone got a source on replacement hubcaps? I've got the aluminim wheels and mine was missing when I bought the truck. Thanks. Don't think I spelled that right, but you get the idea.
#48
The biggest reason to get rid of the stock airbox is that they were poorly designed and if the updated design was not installed, they are prone to leaking and dusting your motor. Well, that, and the increased efficiency and sound of the 6637 setup.
I doubt you will gain 2 MPG though. 1....maybe.
#49
#51
#52
#53
I had an intermittent rough running problem. It didn't resolve though. Instead it developed into a no start condition. I went through every diagnostic I could think of with much help from here with no conclusion so I started cleaning fuel supply and luckily started with the fpr that ended up having a severe internal restriction somehow. Cleared that out, all new fuel bowl and fpr o rings and no issue since. Got the orings from bob because he is closer than clay but they both have them. You can get a diesel rated o ring elsewhere but I don't know the specs.
#54
If you have the FPR clean and you're only getting 52 PSI, you either have a weak pump or you need to shim the FPR. Here is the how-to on shimming the FPR. Cheap (or free) and easy.
TikiWiki : Shim Your Fuel Pressure Regulator 94-97
#55
#56
#57
Just made Bob $40 richer. Got the whole 9 yards, hoses and clamps too. Should be able to do this saturday. He was nice and very helpful. Wait a minute. Guess I'll have to get the shim thing together before I rebuild this thing so I don't have to take anything back apart. Might not make it by saturday.
#59
#60
Bob is a good guy. That's where I got my O-rings as well.
Just use a BB to shim the FPR.
If I recall correctly I just cleaned out the bowl as best I could with rags and then used some brake parts cleaner to degrease the bowl before I reassembled everything. I would think Simple Green would work well too, although I am not sure I would soak the parts in the stuff. It is pretty harmless stuff, but the bowl being aluminum and all, I'm not sure I would leave it soaking for very long.
