60 wheel cylinders
Old 06-27-2012, 01:54 PM
99hosss's Avatar
99hosss
99hosss is offline
60 wheel cylinders
Hey guys, is there a difference in the wheel cylinders of a 60 f100/f250? Also, who sells the best non NOS master cylinders? thanks Fridge Forum
Old 06-28-2012, 04:46 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
I can;t tell you but one good way to cross reference is to use the Rockauto on line catalog. They will also have the new (NOS?) master cylinder, usually a choice of several manufacturers.
Old 06-28-2012, 07:12 PM
spurredon's Avatar
spurredon
spurredon is offline
Per the shop manual,they are different, page 11-50.
F-100 Front bore of brake cylinder is 1 1/16"
Rear bore 7/8"
F-250 Front 1 1/8"
Rear 1 1/8"
Old 06-28-2012, 08:13 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Depending upon its' age, I would be hesitant to buy an NOS (New Old-Stock) brake part unless I could examine it first.For a potentially 50 year old part,my concern would be the rusting of the cylinder walls that could quickly cause scoring, thus leaking.Also,there is the likelihood that fifty year old rubber parts will have hardened,also with the potential to accelerate leaking in the cylinders.
This is true for either master-cylinders, or individual wheel cylinders.Go to a quality auto parts store,such as Napa.They can easily supply your parts,will stand behind them if there are problems, and returns of bad parts will be painless,as opposed to buying through the mail to save a very small amount of money.Finally, if you can, order name-brand as opposed to off-brand or no-name, the support will be better.Raybestos, EIS,are a few trusted names for brake parts,though nearly everything is coming in from that Oriental country across the waters, now.
Good luck.
Old 06-28-2012, 08:59 PM
spurredon's Avatar
spurredon
Good luck.
Didn't they use to be famous mostly for plates, cups and saucers etc...?
Old 06-29-2012, 03:20 PM
99hosss's Avatar
99hosss
99hosss is offline
Thanks guys, yeah I never buy NOS - I think its funny seeing the ebay listings for NOS door seals. I was asking about NON nos cylinders. Great forum- thanks...
Old 06-30-2012, 01:00 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Since NOS and new autoparts store wheel cylinders come completly assembled, please explain how their cylinder walls could possibly be rusty?
How many years have the autoparts wheel cylinders been layin' on a shelf? How many years, vehicles do these cylinders fit besides 1957/60?
And btw: 1959/60 F100 & 250 2WD's use different front wheel cylinders than 4WD's. This same info will be found in the 1961/66 forum, as the OP also asked this question there 6/27/2012.
Old 06-30-2012, 04:33 PM
spurredon's Avatar
spurredon
Ah ha! The rest of the story!
Old 06-30-2012, 04:51 PM
MARC's Avatar
MARC
MARC is offline
wheel cyl
ohh shoot. my front wheel cylinders were rust/ and nasty. I got replacement ones from Napa. parts 9090, 9091. it lists the same 1 1/16 wheel cylinder for both 2wd and 4wd?? they look the same as the ones I threw out. does number dummy have the part # for the 4wd cylinders, and possibly know the difference between 2wd and 4wd front cylinders?
thanks Marc
59 f100 4x4
Old 06-30-2012, 07:06 PM
ibuzzard's Avatar
ibuzzard
I've been b***h-slapped again! I always cherish being humbled by The Master.
I cannot offer any argument, Bill.Not that it would make any differenc.How are you?
Old 06-30-2012, 08:40 PM
spurredon's Avatar
spurredon
[quote=ibuzzard;12010933]I've been b***h-slapped again! I always cherish being humbled by The Master.
quote]
...and you thought that little "Majorette", outfit would save you!
Old 06-30-2012, 09:18 PM
willowbilly3
Some of the reman cylinders might actually be better than new because they reline them with a stainless sleeve. NAPA rep told me that years ago but they have probably changed vendors a dozen times since then. That's one issue with NAPA, they don't actually manufacture parts, just source and label them and I have seen the trusted old Raybestos turn into slime-o Reli-on from one order to the next, with the NAPA label slathered over the Reli-on label.
Old 06-30-2012, 11:54 PM
NumberDummy
they look the same as the ones I threw out. does NumberDummy have the part # for the 4wd cylinders, and possibly know the difference between 2wd and 4wd front cylinders?
1948/52 F1 / 1953/58 F100 / 1959/60 F100 2WD / 1962/65 Fairlane w/10" x 2 1/2" front brakes:
C3OZ-2061-C (replaced 8C-2061-B) .. R/F Wheel Cylinder-1 1/16" / Obsolete
C3OZ-2062-C (replaced 8C-2062-B) .. L/F Wheel Cylinder-1 1/16" / Obsolete
1959/64 F100 4WD:
B9TT-2061-B .. R/F Wheel Cylinder-1 1/16" / Obsolete
B9TT-2062-B .. L/F Wheel Cylinder-1 1/16" / Obsolete
Sheepdog48
02-19-2013 04:38 AM
richardchad
Large Truck
07-19-2011 02:11 PM
Pappys53
04-18-2011 08:33 PM
clutter
12-09-2009 08:56 AM
ynkstr
25
08-04-2009 12:28 PM
Quick Reply: 60 wheel cylinders
