Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 06-26-2012, 11:51 PM
Scolesy8's Avatar
Scolesy8 Scolesy8 is offline
Garage is empty, add now
Scolesy8 is starting off with a positive reputation.
how well will it fit??
how well will a 460 with stock exhaust manifolds fit down in a 77 hiboy or 78 F250 frame? both 4wd. just curious as to your thoughts..
Thanks,
Zach
__________________
'77 F250. Built not Bought.
'99 F350 Powerstroke
  #2 (permalink)
Old 06-27-2012, 12:03 AM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.
As long as you convert it to a truck oil pan and pick up and truck exhaust manifolds, it'll fit like it came in there. Cars have a front sump oil pan and trucks have a rear sump. Also, the passenger side exhaust manifold on the car sticks out too far and you either have to replace it with a truck version, or cut the frame so the pipe will fit. (I suggest getting the truck manifold)
__________________
Alan Fenstermaker
'79 F-150 300-6, 4 spd. 4x4
  #3 (permalink)
Old 06-27-2012, 12:09 AM
Scolesy8's Avatar
that prettty well hit the nail on the head for me..... how tight is the exhaust then?
__________________
  #4 (permalink)
Old 06-27-2012, 08:39 AM
The car manifold will require you cutting an inch and a half off the top edge of the frame. The truck manifold will just clear it.
....or you could buy some fenderwell headers for it and run the exhaust outside the frame rail and be done with it.
__________________
Alan Fenstermaker
  #5 (permalink)
Old 06-27-2012, 08:53 AM
thekingofcows's Avatar
thekingofcows thekingofcows is online now
thekingofcows is gaining momentum as a positive member of FTE.
I don't know, my manifolds came out if a continental and I didn't have to cut the frame. My engine mounts are a little higher than stock though, so that may be why.
  #6 (permalink)
Old 06-27-2012, 04:31 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Workaholic
1978 Ford F-250
My Garage
77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold
X2 on the pan sump swap and get the TRUCK exhaust manifolds, as me how I KNOW, the PO did not do either, just torch notch the passenger side top frame rail IDIOTOT.
And added FRONT blocks to the wore out HB springs AFTER he hit the pumpkin on the pan.
I have a set of Hedeman frendewell exits on another truck, pretty cheap and the rest of the exhaust is a snap.
FYI info....
West Coast Broncos: WCB Extreme Duty Motor Mounts 429-460
When in the JY looking for truck exhaust manifolds the 460 only came out in 2wd truck in 73-79.....you can see a longer difference where they exit further back than the car one's.
__________________
77&79 F250 Rich & Penny
77 351M auto, factory a/c add a leaf/33x12.50's
78 (79 headlights) 460 4 spd, factory a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4 Ext Cab Flareside V-6, 98 Expedition EB 4x4
71 Bronco 302 35" Boggers 5.58 gears spool/locker
  #7 (permalink)
Old 06-27-2012, 11:03 PM
Scolesy8's Avatar
my 77 has hedman ceramic coated fenderwell exit headers... LOVE them! personally, thats the only way to go as far as headers, but trying to get around a certain rule for a certain class of truck pulls. thats y i ask.
__________________
Tags
460, 77, f250, fit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
