Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1989 F600 number decode please?
Old 06-26-2012, 01:45 PM
chaney71's Avatar
chaney71
chaney71 is offline
here is the 1989 F600 numbers for the truck I am thinking about buying to upgrade from the 1969 F600 that I have. Could someone please decode them for me?
GVWR: 20200
1FDNF60NH6KVA41862
9E 52
153 F60202BA8 CB GCV
Thanks in advance.
Mark Chaney
Eastland, TX
Old 06-26-2012, 08:02 PM
chaney71's Avatar
chaney71
chaney71 is offline
another request
Also once the numbers are decoded, could some one tell me what the GCWR or the Max gooseneck trailering capacity is. Or both, Thanks, hopefully number dummy will help me here. I think with the GCWR I can calculate what the trailering capacity would be once I weigh the truck "wet and loaded". I think the GCWR will be the limiting factor since the GVWR is 20200 lbs. Even if the truck weighs 14000 lbs (Which I doubt) that would still leave 6200 available in tongue weight. That would be a really heavy trailer. so I think the GCVR is what I really need, Does this sound correct or is my thinking all wrong?
Thanks,
Mark Chaney
Eastland, Texas
Old 06-27-2012, 02:39 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
20,200 lbs. Gross Vehicle Weight Rating.
1FDNF60H6KVA41862
9E 52
153 F602 BA8 CB GCV
1FD = FoMoCo USA Incomplete Vehicle.
N = Class N: 19,501-26,000 lbs. GVWR
F60 = F600 2WD (gas).
H = 370 2V or 4V
6 = Check digit, FoMoCo internal usage only.
K = 1989.
V = Kentucky Truck Assembly Plant.
A41862 = 1989 Numerical Sequence of Assembly, the trucks specific serial number.
9E = Special White.
52 = Dallas TX Ford District Sales Office, where the original selling dealer ordered the truck from.
F602 = F600 2WD (gas), 20,200 lbs. GVWR
BA8: BA = Charcoal all Vinyl / 8 = 81A Regular Cab.
CB = Clark model 282 5 Speed Direct.
GCV: GC = Rockwell model RS 15-210 Two Speed Rear Axle / 5.86/8.17 / 15,000 lb. Rear Axle Capacity // V = Ford 6,000 lb. Front Axle with P/S.
Old 06-27-2012, 08:04 AM
chaney71's Avatar
chaney71
chaney71 is offline
Sorry
Bill,
Sorry, you are correct, the N should not be there at all. the rest of it is confusing to me because it seems jumbled on the tag. But the best I can tell:
9E = Exterior
WB= 153
TYPE-GVW = F60202
body= BA8
Trans= CB
AXLE=GCV
It is all pushed together and not lined up well on the tag but I am pretty sure that is correct. Did Ford publish the GCWR for this particular truck?
Again sorry and Thanks,
Mark Chaney
Eastland, Texas
Old 06-27-2012, 10:03 PM
NumberDummy
9E = Exterior / WB= 153 / TYPE-GVW = F602 / 02 / body= BA8 / Trans= CB / AXLE=GCV
See edited post 3.
Old 06-28-2012, 08:05 AM
chaney71's Avatar
chaney71
chaney71 is offline
Thank you
Thank you Bill! That's wierd that there is an extra 02 in the numbers of this truck, I wonder if it was a typo or something? I've tried to include a picture of the tag with this post but I can't figure out how to get it done. Anyway, I've got what I needed. Thanks again.
Mark Chaney
Eastland, Texas
P.S. Does anyone out there know what the GCWR of this 1989 F600 is???
Spaz1461
01-06-2018 01:04 PM
big bern
17
02-23-2015 06:15 PM
chaney71
Large Truck
11-02-2012 08:47 AM
chaney71
Large Truck
09-18-2012 12:26 PM
Tomc750
01-06-2009 06:27 PM
Quick Reply: 1989 F600 number decode please?
