1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Theft Light Blinking, won't start...Help!
Old 06-26-2012, 09:35 AM
theboze's Avatar
theboze
theboze is offline
Hi everyone I have a 97 Eddie Bauer Expedition with the 4.6, I just replaced the heater core last week ( removed the dash and all) when I put it back together the truck started fine. I let it sit a few days and went out to use it on Sunday and the battery was dead, not sure what drained it, but I put the charger on it for 20 minutes and went to start it, and it cranked over but wouldn't start. I then noticed the "theft" light blinking like crazy and it won't start. I disconnected the battery for 1/2 hour, like I seen on some posts, but that did not work. I do have a friend that has the OBD scanner from snap on, and I have the owners manuals along with the 2 large factory manuals from Ford on this truck, is there anything we could do to get this thing going without going to the dealer? Right now I am checking things without the scanner because I am off today and he is at work. Any help would be greatly appreciated.
Old 06-26-2012, 09:42 AM
alloro's Avatar
alloro
alloro is offline
Received 4,198 Likes on 2,433 Posts
Do you have a second key to try?
If not, only the dealer will be able to program your keys back into the security system. Make sure you bring all of your keys with you.
Old 06-26-2012, 10:18 AM
theboze's Avatar
theboze
theboze is offline
I already tried the other key and same thing.
Old 06-26-2012, 12:03 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Check the connector and harness that goes to the key cylinder transceiver. Since the dash was out, the connector may be loose or something else in the circuit may have been damaged.
Old 07-14-2012, 07:38 PM
79250ranger's Avatar
79250ranger
79250ranger is offline
I had same issue with theft light blinking... Battery went dead...bought a new battery, problem solved...
Icefan71
1997 - 2003 F150
06-05-2021 02:50 PM
stephenbrust
1997 - 2003 F150
02-27-2011 04:28 PM
markt1993
6.4L Power Stroke Diesel
08-09-2010 06:30 PM
seesaw_4
07-17-2008 06:44 AM
jonesav
1997 - 2003 F150
11-08-2004 09:51 PM
Quick Reply: Theft Light Blinking, won't start...Help!
