1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
7.3 vs v10 gas
Old 06-28-2012, 10:04 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
Didn't mean to repost
  #62
Old 06-28-2012, 10:08 PM
MDSuperDuty's Avatar
MDSuperDuty
MDSuperDuty is offline
I know this isn't exactly the same but when I put a leveling kit in my 2wd twin I beam 96 F150 it's was absolute hell to align. And it ate the outside edge of my tires so fast. There are pivot points in the middle of the axle that create all the issues. Hurt it? Not a chance. Eat tires, probably.
  #63
Old 06-28-2012, 10:41 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
What if I had it alligned after I lifted it
Would I still have trouble with tires
  #64
Old 06-28-2012, 11:04 PM
MDSuperDuty
That suspension was known for eating tires. I think when the suspension components are new things are ok. But once a spring/shock starts sagging a little the arm moves and throws it all off. Anything can lose alignment but those were tricky. IIRC I remember Superlift making a special steering system to help with that suspension. Seriously if you really want to lift a truck save your money for a solid axle or find a 350 in that style as it will have the solid axle. Just easier to lift.
  #65
Old 06-29-2012, 01:34 PM
mudd hog's Avatar
mudd hog
mudd hog is offline
How much does the full kit from superlift cost
  #66
Old 06-11-2013, 12:10 AM
allbusiness101's Avatar
allbusiness101
allbusiness101 is offline
Hello I'm looking at 2 trucks. Both have the exact same 245k on the odometer. One is a 1999 F250 Extended Cab with a 7.3 diesel... the other is a 2001 Crew Cab with the V10. I've heard the diesels can last forever. Would you recommend that I steer clear of the V10 with the same miles? They both appear to be in very good shape. But obviously concerned about the miles. And both could be had for a similar price. Please advise!
Thanks!
  #67
Old 06-11-2013, 12:12 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Miles doesnt mean anything, maintenance does.
  #68
Old 06-11-2013, 12:21 AM
allbusiness101
So is the reason that 7.3 have greater resale value strictly because of their gas mileage? I thought the diesel engines are supposed to last longer as well?
I would primarily be using it for around town use (for family) and then, perhaps once a day I would have two 800 lb motorcycles on it for some local dealer to dealer transports.
  #69
Kdr358's Avatar
Kdr358
Kdr358 is offline
Exactly, I wouldn't worry about the mileage on either motor but I would be concerned with the rest of the truck. Remember a repair on a diesel will cost nearly double that of a gasser. What do you plan on using the truck for? I hope im not opening another can of worms!
I would say V10 for you, diesels do not like puttering around town, they need to be worked and driven at least 10 miles one way to just get the engine up to operating temp. The reason the 7.3 has such a high resale value is because they were arguably the last good, reliable diesel to go in a Ford. A 7.3 will go 500,000+ miles if properly maintained, Most repairs can be made with the average tool set on a weekend. No need to spend big money at the dealer for diesel work. There are a few million mile 7.3's out there. There is a few V10's with close to 300,000 miles on them on this site.
  #70
Old 06-11-2013, 12:38 AM
allbusiness101
Thanks so much. Some would be just around town. But some travel would also be 15-20 mile runs with a couple of heavy motorcycles in the back. In August I'll be using the truck as a roadside assistance rescue vehicle (driving from Denver to Sturgis) and loading heavy motorcycles in the back once i get there.
So I would say an even mix of local and longer highway runs with as much as 1,000 to 2,000 lbs in back (2 full size bikes + the motorcycle loader).
I was also concerned about the gas mileage of the V10. That and you seem to hear about the 7.3's with more miles on the odometer... so thought it was more bullet proof... hence I was LESS concerned about buying a diesel with 244k on the odometer (because according to one post... I might be able to get 500k miles out of it) vs potentially only getting 300k miles on a V10 that already had 245k.
The V10 is a beautiful truck and offers more versatility than the also beautiful extended cab diesel... but just didn't want to be perhaps looking for a new gas engine or rebuild in 50,000 miles. But if I were to need a rebuild engine for the gasser... what might that run me when I need it?
Thanks a bunch in advance. Great community of Ford Owners here!
Last edited by allbusiness101; 06-11-2013 at 01:41 AM. Reason: Made a mistake in asking a question that had already been answered.
  #71
Old 06-11-2013, 03:05 AM
parkland's Avatar
parkland
parkland is offline
Sounds like nothing less than a f-650 would do this job for you.
LOL
JK
  #72
Old 06-11-2013, 06:14 AM
redford's Avatar
redford
redford is offline
Received 1,595 Likes on 933 Posts
An F-150 with the base V-6 engine would work fine. You don't need a diesel or a Super Duty to haul 1600 pounds.
  #73
Old 06-11-2013, 07:40 AM
GoCamping's Avatar
GoCamping
GoCamping is offline
Redford has a point ... but to answer the original question:
Assuming both trucks have been maintained, I'd go with the v10. I own the 7.3 and if I were to do it all over again I'd think about the v10, and this is coming from a guy who tows a 10k 5er a couple times a year.
My truck either sits in the driveway, tows the camper a few times a year, goes to Lowes or I take it sometimes on the 8 miles commute. I cringe when I drive it on short trips and it doesn't get a warmup. With the diesel, you have to be mindful about SCA additive to the coolant, 4 gallon oil changes and a number of other things I've just gotten used to over the years.
Don't get me wrong I really enjoy it but with what has happened emissions-wise to diesels and all the complexity I think my next SD will have the 6.2 gas.
It's true that the diesel will return better fuel mileage, but I think if you compare cost of ownership the v10 is competitive. And it will be quieter than the diesel
Also I would think that because of the market you'd have more negotiating room with the v10.
Just give it a good inspection and find out as much as you can about the maintenance. Don't forget about the tranny. There was something about a mechanical diode in the 2001 trucks but I don't know if that was just in the diesels.
  #74
Old 06-11-2013, 08:05 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
I agree with everything on this page. Redford does have a great point! A nice ecoboost would suit you very well.
  #75
Old 06-11-2013, 12:16 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
IMO short trips aren't really an issue when it's 80+ oitside. My 7.3 sees most if its driving in the summer, pulling a car trailer or my 14' enclosed. I try to avoid short trips as much as possible. A Dino oil change on a 7.3 is about 85.00, synthetic is almost 150.00. I change mine every 3k, I do take short trips in the winter months but when I do I almost never shut it off while running around. You'll be happier with a gasser, a SD is overkill for what you want/need but if you want one, buy one. V10, expect 9-11 mpg avg mileage.
Quick Reply: 7.3 vs v10 gas
