1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
8 Quarts of oil?
Old 06-24-2012, 07:30 AM
GOT-DRT's Avatar
GOT-DRT
GOT-DRT is offline
Originally Posted by acf6
I thought 5.4s took 6 quarts.. 6 brings me to exactly halfway between min and max on the dipstick
6 quarts brings me to about 3/4 of a quart low so I just add the full quart
Old 06-24-2012, 08:20 AM
PA-Mark's Avatar
PA-Mark
PA-Mark is offline
honestly one qt one way or the other would not bother me too much.
Old 06-24-2012, 08:24 AM
kd0axs's Avatar
kd0axs
kd0axs is offline
I believe the older 5.4s take 6 quarts, but the 3Vs take 7.
That's about the same case for me, 7 quarts was probably about 3/4 quart low. The 8th quart brings it just a hair above full.
I wasn't really all that concerned about this, more of a head scratcher than anything. I would rather make sure it's where it's supposed to be on the dipstick than worry about the exact quantity of oil. Even if there is one extra quart in there, I doubt it's going to hurt anything. Now if I was having to put 12 quarts in it, then I would be concerned.
Old 06-24-2012, 09:04 AM
dkf's Avatar
dkf
dkf is offline
Correct.
2V = 6 quarts
3V = 7 Quarts
Old 06-24-2012, 12:22 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Mine take 6 quarts.
If you know someone with a 3V 5.4L engine, maybe you could compare dipsticks?
Old 06-24-2012, 06:21 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
maybe you got a 2v dipstick in your truck. Im sure the 3v has a longer tube and the 2v are shorter. So this will make the dipstick fill lines above where they should be with the longer tube. maybe it was a mistake when installed by ford.
Old 06-24-2012, 07:03 PM
dkf's Avatar
dkf
dkf is offline
The 2007 5.4l 3V in both the F-150 and SD is listed as having a 7qt oil capacity.
2007 Ford F-250 Specifications
Old 06-24-2012, 07:39 PM
lbrjet's Avatar
lbrjet
lbrjet is offline
I have a 2010 F250 with the 5.4L. I never check my oil until the engine has warmed and the oil has had a chance to cool. I have changed it 7 times now and I get out 6 1/4 - 6 1/2 quarts and put in 7. I have actually only checked it a couple of times with the dipstick, but it did seem accurate. Have no reason to check it unless I see evidence of a leak, which I haven't.
Old 06-24-2012, 07:55 PM
Hotpocket's Avatar
Hotpocket
Hotpocket is offline
i always put 7 in mine and it brings me to the max line
Old 06-26-2012, 12:06 AM
maverick22's Avatar
maverick22
maverick22 is offline
Originally Posted by redford
Mine take 6 quarts.
This was bugging me so I went out and measured - right at 39 5/8" to where the base of the yellow cap hits the tube. Mine takes 7qts and is just shy of the full line.
Old 06-26-2012, 12:56 AM
kd0axs's Avatar
kd0axs
kd0axs is offline
Thanks, I will measure mine tomorrow.
Old 06-26-2012, 09:34 AM
LSchicago2's Avatar
LSchicago2
LSchicago2 is offline
Originally Posted by A/Ox4
The proper amount of oil is 15 quarts. 13 in the crank case and 2 in the filter.
That 5.4 will drown in oil!
Strokin-A-2010
2017+ Super Duty
17
01-07-2017 11:05 AM
lundman
6.7L Power Stroke Diesel
08-06-2012 11:51 AM
02GrayPowerStroke
10-14-2010 08:04 PM
61 uni
06-15-2007 08:24 PM
southprk
1997-2006 Expedition & Navigator
11-21-2003 09:17 AM
Quick Reply: 8 Quarts of oil?
