performance chips for 2010 f-150 4.6L
Old 06-23-2012, 04:32 PM
wdbutchreed's Avatar
wdbutchreed
wdbutchreed is offline
I see advertisements for performance chips for my Ford F-150 4.6 L engine. Their ads usually say increase your mileage 4-7MPG, 35-70HP increase and torque increases. Do these really work or are they a rip-off as I suspect. The one that popped up when I visited my local Ford dealer site was for GForce Performance Chips $69. Also they claim they will not void your warranty, how can that be when you have to tap into the wiring controlling the IAT sensor. I bought one of these but I am thinking of sending it back unless I get some positive feed back.
Old 06-23-2012, 08:19 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
you want more power?
go buy a SCT X3 and get custom tunes for the truck written. Be about $400 all told for the programmer and tuning.
I suggest 5 Star Tuning or Troyer
send that POS back now. you are...no, YOU WILL BREAK YOUR MOTOR if you use that thing
that thing is a resistor. you place it between your IAT/MAF and the PCM. it modifies the signal sent to the PCM. basically it tells the PCM that the motor is 30-40F hotter. this causes the PCM to send less gas...aka it leans out the motor.
the more lean the A/F mixture, he more power you make. fine and good until you reach a point where cylinder temps are too high and you melt a piston. a 12:1 is "safe". the 09+ trucks see 15:1 at highways speeds...but that is with Ford's programming
Old 06-24-2012, 05:24 AM
66fdtrucknut's Avatar
66fdtrucknut
66fdtrucknut is offline
The best upgrage performance wise I did with my 4.6 was to trade it in on a 5.0.
Old 06-24-2012, 12:45 PM
wdbutchreed
Thanks for the feedback, this thing is on its way back, I am glad I checked!
Old 06-25-2012, 03:11 PM
D8chumley's Avatar
D8chumley
D8chumley is offline
Resident smarta$$
You will never see those gains out of any chip or programmer in a gas motor. Contact Mike @ 5Star, I run his tunes in mine and the shifting alone is worth the price. You won't read anything bad here about him, I have no experience with Troyer however.
Old 06-27-2012, 12:29 PM
2ndStroke's Avatar
2ndStroke
2ndStroke is offline
That ad is total bogus, you were right to suspect its a rip off. A good out of the box tuner for the 4.6 is Edge CTS. Paid 585$ for mine.
Edge Products| Products
Badfinger Motorsport
Modular V8 (4.6L, 5.4L)
12-01-2015 12:59 AM
srb1194
2004 - 2008 F150
17
05-01-2010 01:30 PM
Troyer Performance
Computer Chips & Tuners
25
12-15-2006 10:15 AM
wcraige12
10-20-2004 11:29 PM
RoadRash
09-09-2002 07:40 PM
Quick Reply: performance chips for 2010 f-150 4.6L
