New York Chapter Join Chapter, Leader: tiny1
New Inspection Regs foe Diesels
Old 06-23-2012, 09:25 AM
GLR's Avatar
GLR
GLR is offline
This is "effective July 1, 2012, all model year 1997 or newer non-exempt diesel-powered motor vehicles that have a GVWR (gross vehicle weight rating) under 8501 pounds (hereafter referred to as "LDDV") are subject to an OBD II emissions inspection, in addition to the safety inspection. (A LDDV less than two model years old, registered as "historical", or 26 or more model years old is exempt from the emissions test.)"
This is from NYVIP Message 82 dated 6/20/2012
This seems a little strange now as the DMV has limited the number of inspection stations per county because, they "don't have the resources" to check on the current stations.
Old 06-25-2012, 08:16 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Interesting - here on Long Island, there is still a plethora of inspection stations at local mechanics.
They have actually stopped sniffer-checking my 2001 V10 - so no emissions inspection whatsoever for my truck. I figured they couldn't justify the cost to the mechanics of having a separate sniffer setup that must cost big $'s.
Old 06-25-2012, 08:35 AM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
Morning Art.... are they still doing an emmissions check on your truck by using the ODBII port??
Old 06-25-2012, 09:02 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Nope, they never did. My truck is OBD-I - not -II - no catalytic converter monitors, nor O2 monitors.
Because it's a passenger vehicle with registered weight of around 5600 lbs, the answer was to manually change the weight code to >8500lbs GVWR and the machine would call for an idle-sniffer check. If they didn't manually change the weight code, it would call for an OBD-II check and fail.
If it was commercial, and the reg had the GVWR on it, it would automatically pick that up and call for an idle sniffer check.
Now, they don't even bother with the idle-sniffer, and it's just a safety check.
Old 06-25-2012, 09:11 AM
GLR's Avatar
GLR
GLR is offline
And to top things off, a new inspection machine will also be required.
speakerfritz
1999 to 2016 Super Duty
12-14-2015 08:27 PM
Liquid10Rider
02-27-2013 02:31 PM
Homepride
Alberta Chapter
03-04-2011 08:00 AM
krewat
42
02-15-2011 07:09 PM
LightningWolf
03-27-2007 12:47 PM
Quick Reply: New Inspection Regs foe Diesels
