Heater Hose Valve
Mine currently has the valve in the line coming back from the heater core going to the water pump, it didn't seem right to me, it seems like how you said, you'd expect this to be cutting off the water coming in to avoid the hot water water & pressure in the heater core for no reason.
I just looked it up. It goes to the top of the intake area by the thermostat housing. Go to this link and see for yourself. http://www.fordification.com/tech/im...s_integral.jpg
Splices into the inlet to heater core heater hose.
Applications: 1968/72 F100/750 // 1963/67 Econoline w/deluxe fresh air heater // 1965/66 F100/1100 & 1967 F100/750 w/deluxe fresh air heater.
Lineman113: Open your peepers and take a look-see at the Ford truck parts catalog diagram you posted. This valve does not mount on the engine.
D is the heater water valve and as you can see in the pic, it's located on the right (passenger) side inner fender apron, splices into the inlet to heater core heater hose.
C3UZ-18495-A .. Heater Water Control Valve-Cable operated (Motorcraft YG-133) / Available from Ford.
Almost_A_Merc
10-20-2005 08:20 PM
