Herculiner truck bed liner
So this weekend my project is getting windows tinted. Do an exhaust mod. Also Putting on a DIY Herculiner bed liner kit. As well as fishin pole holders in my bed. Anyone got some good tips or tricks? I know that this is going to take a long freaking time to do it but it will be worth it.
Sand your bed really well, tape off where you don't want liner and use that toxic stuff(can't remember what it's called but you have to get it at a hardware store) the instructions call for to prep the area. You don't want to paint it on, use the roller and a paint brush to get consistent coverage. Make sure it's mixed good so you don't get clumps and avoid caking it on. Use gloves and clothes you don't care about, cause it won't come off. I did two coats and let dry a day in between. Turned out ok, I have a bed cover so it doesn't get alot of sun and it has held up well for 5 years. Good luck.
Thanks i appreciate it! I am happy witht he way it turned out. Wasn't expensive and I spent once day sanding/prepping and one day painting. Also I'd much rather have this than no bed liner at all. next up is restoring the rail caps back to life. This time I will take before and after pics to show comparison.
I havent used Herculiner yet, but I was wondering if you guys think it would work for my camper????
I have a camper trailer and the roof doesn't leak, but I figured if I bought the white herculiner that would be a forever seal instead of the garbage they recommend you to use.
I've never seen anyone do it either so I thought it would be cool to do the roof and maybe 3-5 inches down the front back and sides.
There wouldn't be any use either, basically wind, sun, and water.....
Thanks.
Thanks.
