door sheet metal repairs
A while ago I repaired the doors sheet metal of my 1951 F1. The bottoms and corners were rusted out.
First I started repairing the corners to keep the it all into shape.
As you can see the reinforcements is completely gone. So I had to make myself a new one.
I started with this piece of sheet metal and started forming it.
I had to cut the sides to give it the curve it needed.
The end result, after welding it back together and make it fit onto the original reinforcement.
The result after some welding and grinding.
The corner as seen on the picture had some rust holes so I decided to replace it too.
Made a little patch panel.
Spot welded it into place.
Test fitted a another patch panel.
Shaped it a little more.
Quite a few holes Had to replace the complete bottom too.
Took half of the bottom out to maintain the doors shape.
Looks quite bad.
Made a patch panel for the whole door and cut it in half later.
Test fitted the panel and make sure its all strait.
Welded it into place.
The other side.
Some rust holes into the doors skin.
Cutted it out.
Made a patch panel.
Test fitting.
Some welding.
Some more welding and grinding.
The endresult
I hoped you guys enjoyed it:P
I've got only one question. I haven't got thedrivers side door latch (without the keylock). Is there anyone who has one laying around that he's willing to sell? Or knows where I can buy them?
If you guys I interested I have got more sheet metal pictures that may be intersted.
Kyle
Looks quite bad.
The other side.
Cutted it out.
Made a patch panel.
Test fitting.
Some welding.
The endresult
Kyle
Excellent work showing what can be done with a minimum number of tools in the home shop. I assume you will return and weld the patch panels in solidly?
One suggestion I would make is if at all possible make the corners of your patches round (trace around a soda can or roll of duct tape) rather than square. It is easier to cut them square, but a circle is a much shorter distance, so less heat is generated when welding them in, especially in the very corner, so you are less likely to get warping and distortion.
Nice work, You make it look so easy. How many hours do you think you have into that repair?
I'm pretty sure I have an extra drivers side door lock mechanisim, (plus another spare rusted out door with one in it) I'll look for it. you can send me a PM or email if ya want to just click on my user name.
I have the left (drivers side) door latch mechanisim which includes the lock mechanisim found only on the five star trucks. after i re-read the original post im not sure if your looking for the one without the drivers lock or the five star option with lock? either way ive got extra mechanisim.
