Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-19-2012, 09:46 PM
motohead68 motohead68 is offline
Garage is empty, add now
motohead68 is starting off with a positive reputation.
97 Ford conversion van 4.2l
I need to know if, anyone has experianced a P0306. have changed all plugs, wires, coil pack, injector, ran comp. test. all check good. put an inline spark tester, in place, clear code and drive it for about 10miles, then spark fades , which trips the P0306? put diffrent coil on and same thing. I can read schematics, but cant find at local Ford tech. library. any sugestions?
  #2 (permalink)
Old 06-19-2012, 10:09 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
Welcome to the forum. I'm going to move this to the 4.2L forum in hopes that you will get more info. I am wondering if it may be a harness issue. You might try some contact cleaner on the coil primary plug.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
Tags
1999, 42, 97, conversion, diesel, ford, mpg, performance, specification, tech, van, vans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
