Help troubleshooting P0301 on 97 4.2L F150
I have a 1997 f150, 4.2L, 5 speed, 121K miles. I am pulling a P0301 code ( misfire, cylinder 1 ) Replaced sparkplugs and wires. Still getting the fault. Truck runs well. The code seems to come on after about 10-20 miles at moderate rpms ( 1-2 K rpm) Have reset and consistently comes back. I am thinking COP; unfortunatley, it is a one-piece unit so changing COP to see if the fault follows to another cylinder doesnt appear practical. Any tips or suggestions for next steps? I need an inspection sticker asap!!!
c-o-p
You're 4.2 v-6 dosen't have c-o-p "Coil On Plug" does it? Don't think they do. If this is a one piece coil pack that is most likely you're problem. Some of these packs are seperate but are bunched togather and do look like they are one piece.
Try an inexpensive spark tester that you can place on the plug wire itself, with the truck running, and check for a good spark.
Bob
Bob
Clarification...
Guys; Thanks for your suggestions. Perhaps COP was the wrong terminology; Here is a link that shows the ignition coil pack that my wires plug into on the top of my engine. Can these be separated out to switch positions???
http://search.ebay.com/4-2l-coil-ford_W0QQfromZR8QQsatitleZ4Q2e2lQ20coilQ20fordQQss PageNameZRC0021
Trailblazen
2009 - 2014 F150
16
10-12-2016 11:33 PM
jmccracken1214
09-21-2016 07:50 PM
Alanpeder
12-20-2015 06:09 PM
