i am putting a zf5 behind the 460 in my '97 fsd in place of the auto thats there now. i have read that the engine will run better with the computer for a manual trans truck.
can i assume that the computer from any 460 powered truck with a 5spd is going to work (ie f250/350/fsd)? or only a fsd?
Reason: not getting responces
the more i look into this, it appears the pedals, bracketry, master and slave are not going to work on my truck. the truck is a '97, and all the donor parts came from an '89. the trans itself will bolt up, right?
Not sure about the computer but the trans will bolt up if it's from a 460.Did you physically try to bolt up the pedal assembly?You may need to install the brake and clutch pedal as a pair.I don't believe that there were any changes in the pedals from 89 to the mid 90's.You might have to find some untapped bolt holes.Everything should be there to install the clutch pedal assembly.
upon exhaustive research, it seems that the the pedal bracketry is different, but it seems i can use the '89 master/slave assembly with the correct pedal bracketry.
anyone have a pedal assembly appropriete for a '97 fsd?
