1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Lift blocks
Old 06-15-2012, 03:11 PM
Green Giant's Avatar
Green Giant
Green Giant is offline
Lift blocks
My son just bought an 03 f-350. Can we use the 2" stock lift blocks that were removed from the rear of my 01 excursion to lift the front of his truck?
Old 06-15-2012, 03:50 PM
schmidt64's Avatar
schmidt64
schmidt64 is offline
Better off buying a replacement 5-6" block, stacking blocks is not recommended.
Old 06-15-2012, 04:01 PM
lukeg's Avatar
lukeg
lukeg is offline
A block for lift in the front is never a good idea. I was at my local spring shop 15 min ago pricing out leafs for the front pack. $160 for both sides. That would be your best bet. Another possibility would be a mini leaf pack. Good luck!
Old 06-15-2012, 04:05 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
You absolutely cannot use them for that. You have a number of options, including replacing the pack with lift springs, using a mini pack, an add-a-leaf, or lift shackles.
Old 06-15-2012, 05:23 PM
FordGuy85's Avatar
FordGuy85
FordGuy85 is offline
I just raised the front of my truck 2.0 inches with some lift shackles for the front springs. Here is the thread.
https://www.ford-trucks.com/forums/1...-shackles.html
I think you can buy them from eBay, bit I made mine. I made them much stronger and I got a kick out of doing it.
The truck drives just as it did before. Works great.
Old 06-15-2012, 09:22 PM
schmidt64's Avatar
schmidt64
I definitely didn't see the part about wanting to lift the front, glad everybody else did though haha
diesel-fitter-bum01
04-09-2010 11:41 AM
Powerstrokin_350
01-15-2009 02:42 PM
Tha_Stepside
12-12-2008 10:45 PM
jjnord
01-06-2007 08:58 PM
KRMFiero
12-24-2001 10:23 AM
Quick Reply: Lift blocks
