1970 f100 9" axle shaft???
Old 06-13-2012, 09:59 PM
70 LIGHTNING's Avatar
70 LIGHTNING
70 LIGHTNING is online now
4wd Low
Hello, I am new here and hope you guys can help me out!
So here is the problem im faced with... I bought a 1970 f100 2wd last year and this last weekend I blew up the rear end in it. I cant find any info on aftermarket axle shafts for this truck at all! I just bought a new 31 spline 3rd member but now I need axles... Who makes them? What is the length of them? Are both sides the same length? Are they the same as any other popular axle, like a 60's Mustang or something?
Thanks for any help!
Old 06-14-2012, 01:42 AM
RichS2659's Avatar
RichS2659
RichS2659 is offline
For all things 9 inch, go to the original experts, Currie Enterprises is the answer.
Old 06-14-2012, 06:07 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
Passenger car 9" axleshafts are not the same as F100 and are usually right/left specific. F100 axle shafts are the same right/left.
The original expert: FoMoCo, everyone else is secondary and many of these so-called "experts" are totally unaware of the following:
1968/72 F100's were available with two different 9" rear axles.
One has 28 spline axleshafts (C8TZ-4234-A), t'other has a 9 3/8* ring gear and 31 spline axleshafts (C8TZ-4234-B).
Only five parts are the same 9 vs 9 3/8: Housing gasket, pinion seal, pilot bearing retainer, one pinion bearing and race.
EVERYTHING else is different! // How many splines does your axleshaft have?
Old 06-16-2012, 07:03 AM
70 LIGHTNING
4wd Low
They were 28 spline. But I just ordered up a 31 spline 3rd member so now I need axles. I cant believe that nobody in the aftermarket makes shafts for an f100!!! Ive called EVERYWHERE! They all tell me its gonna be a custom order deal... Anyone know who may have a stock set?
Old 06-16-2012, 08:14 AM
NumberDummy
What's the application for the 3rd member?
Old 06-16-2012, 08:28 AM
70 LIGHTNING
4wd Low
??? im not sure what your asking... arent all 9" 3rd members the same reguardless of application?
artscott61
20
06-05-2017 03:51 PM
6t6merc
10-21-2013 08:30 AM
jjurva
01-04-2012 11:25 PM
bob_351
03-04-2011 05:59 PM
1982fordf100
04-25-2005 11:58 AM
Quick Reply: 1970 f100 9" axle shaft???
