Turbo Out of a 95 PS
Old 06-16-2012, 05:48 PM
njoenks's Avatar
njoenks
njoenks is offline
I'll have to check that part out at first glance both engines look identical except for the turbo, I'll check it out to be sure. Thanks
Old 06-16-2012, 07:02 PM
farmert's Avatar
farmert
farmert is offline
Where is the oil fill? Front center= IDI passenger side valve cover=Powerstroke. Injector pump and lines = IDI non=stroke.
Old 06-16-2012, 09:44 PM
rolape2's Avatar
rolape2
rolape2 is offline
P'stroke turbo on a 6.9. Done by PO. It appears to be an ATS kit modified to hold P'stroke turbo.
Old 06-17-2012, 03:04 PM
kobaltblue's Avatar
kobaltblue
kobaltblue is offline
Man thats fugly!^^^^
Old 06-17-2012, 03:29 PM
johnboggs21's Avatar
johnboggs21
johnboggs21 is offline
but does it work? Thats the real question
Old 06-17-2012, 08:56 PM
rolape2's Avatar
rolape2
rolape2 is offline
Yeah I agree with the "fugly", but it does work. Only good for about 8PSI unless I turn the fuel up too much and the EGTs run too high. I want to find a IC and eliminate the ugly feed from Turbo to intake.
I just got my spare exhaust manifolds back from getting bead blasted. I painted them with ceramic paint. Going to install them and wrap crossover pipe to see if I can get more boost that way.
When I get the exhaust done I will have an EGT gauge pre and post turbo. I am going post pictures/video of both side by side to show differances. Boost gauge in mounted by 1 of the EGT gauges so it will show also.
I know a P'stroke guy that has a spare Wastegated turbo, I am considering trying to get that to work.
Jzisakis
08-20-2018 01:54 AM
Sparkplugless
09-22-2012 08:12 PM
Ford_Maniac
07-17-2010 10:16 PM
79f-250custom
16
04-03-2007 10:31 PM
Quick Reply: Turbo Out of a 95 PS
