1980 Ford Courier
Old 11-29-2010, 09:18 PM
Rulebreaker's Avatar
Rulebreaker
Rulebreaker is offline
1980 Ford Courier
I've got a 1980 ford Courier made in Japan by Toyo Kogyo. It has a 2.3L I4. Is this the same engine used in the Ranger or is this a Jap built engine? RB
Old 11-30-2010, 11:14 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
It's the Ford engine. Couriers with the 2.3 are Ford engines, the 2000 and 2600 are Mazda engines.
Old 06-08-2012, 01:42 PM
Muchacho Chicho's Avatar
Muchacho Chicho
Muchacho Chicho is offline
1979 Ford Courier Engine CID question..
Hello, my name is Emilio, and recently I purchased this little nice Ford Courier and I don't know the engine size to purchase spark plugs??
I try to decode the VIN number,,but have no luck,, how can I find out what size of engine I do have?? all I know is that is a 4 cyl. 6 speed stick.
Thanks.
Old 06-09-2012, 08:39 AM
Rulebreaker
Look on the emissions sticker under the hood. The displacement should be listed near the bottom of the sticker
Old 06-09-2012, 12:57 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
If that is missing or has been painted over, look at the dist. Does it come out of the head near the front of the engine, or stick out the side of the block part way back?
Dist in the head = Mazda 2.0L (wide cast aluminum valve cover)
Dist in side of block = Ford 2.3L (narrow stamped steel valve cover)
Old 06-09-2012, 02:38 PM
Muchacho Chicho
Hello, thanks very much, the sticker with the dislpacement still there and yes, the Valve cover is the stamped stheel, so it's a 2.3 Ford Engine, that's really what I want to have.
Thanks very much for the help.
I got the spark plugs, whires, and air filter plus the front shocks to be installed today. will place some pictures later.
Thanks again.
emilio.
sawmaned
Ford Truck Parts for Sale
19
05-20-2017 01:35 AM
ss0345
08-15-2015 09:34 AM
postmaster ford
4 Cylinder Engines
05-24-2012 12:04 PM
woopud
04-16-2003 12:25 PM
Dutchworks
02-03-2002 02:20 PM
Quick Reply: 1980 Ford Courier
