1978 - 1996 Big Bronco
8.8 rear end clunk
Old 06-20-2012, 06:53 PM
biguglylongbed's Avatar
biguglylongbed
biguglylongbed is offline
No need for friction modifier, I have no LSD. Brake fluid is fine. No leaks, no change in the level. Just no pressure on the pedal. Brakes still work, just not nearly as well as they used/need to.
Old 06-20-2012, 08:08 PM
NewEnglander's Avatar
NewEnglander
NewEnglander is offline
Bleed the brakes?
Old 06-20-2012, 09:07 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Originally Posted by NewEnglander
Bleed the brakes?
I second this, try bleeding them and checking the amount of pad left on the shoes/brake pads.
Old 06-21-2012, 11:22 AM
batchman's Avatar
batchman
batchman is offline
Originally Posted by biguglylongbed
Now for the new problem: No brake pressure at the pedal. Pumping does not increase the pressure either. No visible leaks I've found as of yet.
Is the pedal hard? If so then master cylinder and bleed are fine.
If you have lost braking effectiveness but not braking I think you have lost the power booster. Check your vacuum line to it.
Good luck,
- Jeff
Old 06-21-2012, 11:41 AM
biguglylongbed
I will definitely check those vacuum lines. Its strange really, when the truck is off, I have a stiff pedal but the pressure doesnt seem to increase. But as soon as I start the truck, pedal goes to the floor and brakes still engage just veeeeeerrrrrryyyyy sloooooooowly. What are the chances my check valve went bad?
Old 06-21-2012, 01:17 PM
biguglylongbed
So the vacuum lines seem fine, no visible or audible leaks. I just drove it around the block and it will still lock up the tires, just at the floor instead of a little further out like before. Fluid level is still the same and I haven't messed with anything. Brake pads have plenty of meat left but I haven't checked my drums yet(can't get my damn wheels off in the back) Sad part is, when I was living in Greenville, I would have probably drove it like this but in the mountains thats a no no. I don't want to go off the road up here and end up 100 feet down in some ravine. Stumped!!!
Old 06-21-2012, 01:41 PM
GruesomeJeans
I wouldn't want to drive that anywhere... The last thing i could think of is air in the lines... That is the extent of my brake knowledge besides adjustments but that doesn't apply for the front i don't think. And if there was air in the lines it would have a spongy feel rather than going to the floor unless there was nothing but air in there... Which is unlikely.
All i can say is best of luck at this point, sorry.
Old 06-21-2012, 03:50 PM
biguglylongbed
How would I develop air in the lines all of the sudden?
Old 06-21-2012, 04:49 PM
GruesomeJeans
You got me on that one, i doubt it is air, but my knowledge is limited so that is the best i can think of. It might give someone with more experience a better idea of the issue.
Old 07-26-2012, 05:06 PM
gr8grizzly1's Avatar
gr8grizzly1
gr8grizzly1 is offline
I had a similar problem with my 87 f-150 4.9L.....turned out to be the ABS dump valve. If they get even a small piece of grit in them, they can stick and cause soft pedals.
Old 07-26-2012, 05:24 PM
biguglylongbed
Where can I find this valve? I'm gonna check to see if I even have ABS.
Old 07-26-2012, 07:01 PM
moritz1024's Avatar
moritz1024
moritz1024 is offline
i have a brand new detroit tru trac for the 8.8 i think 31 spline not 100% sure and 4.56 gears just sitting around i bought for a project but never got around to it. needless to say if u need something im looking to part with these brand new parts lol
  #28
Old 07-29-2012, 05:52 PM
biguglylongbed
Got a front gear too?
crivaro
2004 - 2008 F150
04-29-2012 05:00 PM
kent521
02-16-2011 06:23 PM
ErrorS
21
10-02-2010 12:25 PM
Highguy
09-05-2004 04:29 PM
blackf15083
04-25-2004 03:18 PM
Quick Reply: 8.8 rear end clunk
