coolant "power" flush?
Old 06-11-2012, 01:16 PM
bbender85's Avatar
bbender85
bbender85 is offline
alright, i've been digging for the the last 2.5 hours on this, to no avail. my key words turn up endless posts on here and google in general for the "flush" n' fill method for "power" stroke diesels, haha.
anways ,would having an oil change place do a coolant power flush save me any time servicing the coolant system? i've read through all the testemonials of people flushing up to 12 times before the sytem is clean, so in my head i'm thinking have an oil change place backflush my system, then come home and drain the radiator and both sides of the block and refill with distilled water and CAT approved EC-1 ELC coolant.
thoughts?
Old 06-11-2012, 01:31 PM
bowbender_1969's Avatar
bowbender_1969
bowbender_1969 is offline
What are your delta's running at presently?
Old 06-11-2012, 01:56 PM
bbender85's Avatar
bbender85
haven't checked them just yet. just bought the truck a few weeks ago, so not knowing it's maintenance history i just want a somewhat-clean slate. an oasis reports that the oil and EGR cooler were replaced at 99k (142k now).. which i would think in 99,000 miles most of the casting sand would have made its way through the system and into the old oil cooler before replacement.
Old 06-11-2012, 02:45 PM
bowbender_1969
Best bet would be to get a ScanGauge II and check everything you can with it. Then you can monitor everything down the road also.
Old 06-11-2012, 06:44 PM
69cj's Avatar
69cj
69cj is offline
thoughts?
Personally saving any time vrs. knowing it's done right doesn't wash with me. How much time and money does it take to fix screw ups?
Old 06-11-2012, 11:09 PM
chetspencer's Avatar
chetspencer
chetspencer is offline
Search for "oil cooler back flush". There is Garden hose n tap water version or Chemical \ water back flush with a transfer pump version. Other cooling system flushing method risks clogging the oil cooler even worse than it is.
1texbabe
1999 to 2016 Super Duty
07-15-2019 08:03 AM
pickle40
02-07-2015 08:19 PM
waterboy_fishing
12-30-2011 07:02 PM
spindler52
12-12-2011 07:46 AM
jarmbrester
08-24-2008 10:37 PM
Quick Reply: coolant "power" flush?
