Let's be honest, ByPass filters, are the REALLY worth all that extra money?
Is your oil really that much cleaner? How many of you running by pass filters still have that occasional injector failure? The only reason I would consider running them would be to keep the oil in like new condition and the dirt and soot out to help with injector durability. No extended change intervals for me. Be honest now! don't try and sell me just cause you spent the money! Tell me you've run a by pass for 100,000 miles or more with no injector failures and yur oil looks new when you change it or something like that! no BS please!
I wont try and sell you nothing
It may keep the oil cleaner help reduce the soot anyway
BUT its NOT Going to keep it in like New Condition since the 6.0L SHEARS ITS OIL so 5k-7.5k oil changes recomended
Lots Go 5K oil changes But I dont think 7500 oil change to bad either but NO MORE
Dont do like some think They can run that amsoil and go 15K-20K NO NO BAD then they blame Ford when its there fault
Tor me, I would NEVER run extended changes! I just want to know if the benifits of by pass give you a much cleaner oil at the end of the 5000 mile interval. Would it be clean enough to improve injector life significantly, as in double, if so maybe it would be worth the added oil change cost and up front purchase cost.
on
1 Post
Many years ago over at TDS I compiled member's oil analysis reports for both the 7.3L and 6.0L. As mentioned, the 6.0L shears down the viscosity modifiers so it brings the oil to the base stock viscosity. ow if you only using a straight viscosity oil like 30wt, then you probably could extend the oil change intervals.
From the 7.3L side, there were people who kept the primary oil charge over 50k miles, adding only with primary and bypass filter changes, which usually kept the additive packages up. Soot in the modern engines is not the issue of the past, so the bypass filters use is primarily for debris retention. Typically unless the oil got contaminated with high levels of coolant or iron, the labs were fine with the extended oil use.
Here is one answer you were asking for:
150,xxx miles and original HPOP + injectors.
The oil being cleaner just by looking at it? I do not know of any oil from any engine that looks new when it is time to change it. The function of heavy duty engine oil (HDEO) use in a diesel application is to suspend the soot particles until the oil can be changed. If you want to learn more, check out this excellent oil forum Bob Is The Oil Guy - Forums powered by UBB.threads™
But I thought I saw a post about 6 months ago about a member who did used oil analysis (UOA) on his rig with the bypass and saw no change in the condition of the oil, so he took off the bypass.
All of that being said, I am leaving on my Franz bypass as the filters are about $1, so outside of the initial investment 7 years ago ($200), there is no negative side.
I'm running an Amsoil bypass setup because it was given to me by a friend. He used the same setup on his 7.3 and went 80k miles between oil changes (using Blackstone OA as a guide). He bought the setup for the 6.0, but never got around to installing it.
Anyhow, I change at 7,500 miles and just consider the bypass filter to be extra. As was said above, I figure it can't hurt and can only help.
Bypass filtration systems were beneficial "back in the day."
Soot particles were larger. Oil quality was much lower. Engines didn't physically destroy the base oil. Additive packages were a larger proportion of oil volume. Tolerances in the engine were much larger.
The way the bypass filtration systems worked was that you changed the oil FILTER at the recommended oil change interval, and replaced the volume of oil that the filter carried. The normal filter kept the boulders and trees under control, while the bypass filter pulled out the soot. The additive package was renewed by the make-up oil (both between-change and at-change).
Nowadays, bypass filtration doesn't get you much more than a lighter wallet. Today's oils and additive packages are much more robust, and tolerances are much tighter than they used to be. The engines just aren't as forgiving as they used to be in regards to oils.
Why risk a $20K engine on a $50 filter?
-blaine
-blaine
We had a bunch of them on our fleet at work. Ended up replacing most the cams, and a few turbos on the engines that had this so called "wonder filter" on them. I know a cat c-10 is a little different than a 6l, but for what it cost to do one cam we couldve changed the oil in 1 engine 10 times. I would never run a bypass oil filter of any kind on any engine i owned. Keep up on the maintanance of your 6l and itll be happy for a long time.
My position is adding extra filtration and keep a normal maintenance schedule. An umbrella won't stop it from raining. But it will keep you dry when it does.
