Kick down linkage.
Kick down linkage.
I was just curious if anybody's truck does what mine does.
Say if I'm going 45mph and mash the gas, the trans will kick down a gear and go!.
Now when I'm doing about 60mph and mash the gas, all it does is accelerate,
it will not kick down a gear like it does when I'm going 45mph.
Is this normal for the C6 auto trans?
I have the kick down rod installed on both ends, i did a search, and really couldn't find out how to adjust the rod if any adjustments are even allowed.
I know there is a screw on the linkage on the carb, so how would i adjust that?
Just a guess. I could be wrong...
-Jameson
on
For my 429 (just for reference I check today) I'm turning 2700 @ 60mpg and when I put it to the floor she jumps to 4200rpm and kicks out into third @ 75mpg. C-6 4.10 & 33's
Here's the adj procedure...
Tried to follow the adjustment procedure, and when i open my throttle all the way, and push the lever linkage for the kick down rod all the way till it stops,
i have way to much gap between the two levers and the adjustment screw is about a 1/4 or so to short.
I physical can not obtain the required .060 gap.
Is that diagram for all model years trucks?
on
When I pulled the 400 out of my truck to swap in a 429 I had to make an extension to the linkage. They make a few different linkages so you might have to find another or extend yours. I think they even make an extension kit. I have to look for the link though....
Something like this; from another posting....
on
We like pics!
But it is too short....
Yes they did.
Back your adj screw off to half way. Then make an extender to make the adjustment correct. That way you will have enough range thru the adjustment screw for fine tuning to what works for your driving style. The factory adj allows for .010 to .070; I like mine to downshift just before the pedal is on the floor....
