Rear door lock problems! Can't lock the rear door when I need to park it! Help!
Ok, so I sprayed some wd40 in there and worked it in. The lock works with key. Only problem now is that the lock won't lock electronically (but it will unlock ).
I'm grussing the problem is with the little resistor inside the motor. Another project for another day. Thanks for the all the help guys.
Wouldn't lock/unlock all the time. Only if I pressed the lock button on the remote several times it would fully lock and vice versa.
Resolved it after spraying silicone spray on the mechanism (not the lock).
Remember, wd40 is not long term lubricant.
Yeah I'll have to get some silicone spray to fix it for good. I'm just glad I don't have to replace the actuator like the mechanics told me .
Does anyone know any good forms on the how to mod the front and rear door actuators (the tin foil fix)? I tried to do it the other day (from a youtube video) but I did something wrong so I'll have to do it again when I have a change.
I just did mine today. Uploaded some pics of it here.
https://www.ford-trucks.com/forums/1...with-pics.html
2001 Excursion, rear lift gate lock
2001 Excursion, rear lift gate lock. I have done the actuator mod, put a new actuator in, and removed, cleaned and sprayed the lock mechanism and it still wont work. I works fine lock/unlock with the key. Just wont work with the key fob. I know I am getting power to the back also. Any idea?
hellmary
08-10-2013 06:23 AM
