1964 F100 Horn Ring Assembly
I have a 64 F100 custom cab with the three spoke steering wheel horn ring and am trying to figure out the horn ring assembly. I don't understand the contact that makes the horn work. Under the horn ring there is a metal coil spring. There is a contact brush assembly that makes constant contact with the back metal of the steering wheel. My horn blows periodically when I go over bumps, but nothing happens when I press on the horn ring. I've got a new contact brush assembly. I thought I read on here that 2 are required, but I only see one. Any help is appreciated. Thanks.
CODZ-13A813-A .. Horn Ring Pressure Pad / Reproduced
Applications: 1961/70 F100/250 & 1967/70 F350 w/a 3 spoke steering wheel / 1960/66 Falcon/Comet/Fairlane/Mustang/Galaxie/LTD/Bronco.
Over time this rubber pad flattens out/distintigrates. Most people are unaware, so they replace everything horn related, the horn still won't blow.
Take a look-see on page 20 in DC's 1957/66 truck repro parts catalog for a pic (# F) of the little charmer. 2011 DC paper edition sez: $12.00.
Note: Take a close look at the horn brush, there's a thin copper wire inside its coil spring that is notorious for snapping.
C2OZ-13A821-A .. Horn Brush and Insulator Kit. The insulator fits into a hole on the outside of the steering wheel FIRST, followed by the brush.
When people remove the wheel, both of these parts can fall out. So make sure you have the insulator, and the copper wire is intact, or the horn won't blow.
Parts catalog pic shows rounded end of brush towards horn ring, flat end inserts into steering wheel.
ffillah
09-05-2012 01:18 PM
chaser1602
10-01-2009 09:58 PM
dcubedus
03-24-2007 05:56 AM
