DiMora's 400 build - part deux
#151
. Multiple coils seem to go bad in 10 years... single coils last 20-40 years... but, at this point, I have no idea why... anybody know?
#152
Thanks for the clarification. I'd looked at that dizzy and realized it takes the MSD box, so was confused.
I'll stick to DS-II as the theme of my build is "as Ford would have done it", so the red MSD box and dizzy cap would be out of character. And, I'm convinced that a good, strong single spark will ignite the mix if it is within reason of 14.7. And with the AEM I can get it there. So, there's no need for multiple-spark discharges - especially if they begat the problems you've had!
#153
As I sit here this rainy Sunday in Georgia, drinking waaay too much coffee and enjoying the internets...I am thinking about some additional troubleshooting before I pull the distributor.
I am contemplating the possibility of a bad cap / rotor on my MSD, and an intermittent coil. Since all those parts are relatively inexpensive, and spares for each of those are never a bad idea...I think I'm going to go hit AutoZone and pick them up. If it turns out it is NOT the coil and cap / rotor...I have spares...if it is...problem solved!
I'll make sure I keep you all advised as I troubleshoot. I've been on the MSD forums all morning as well...and some users have reported intermittent coil issues.
#154
#155
What is your starting problem. Is it Hot Start?
I used to have that problem, until I went to a permanent magnet Hi-torque mini-starter. They need less Voltage & Current than those old Ford starters.
The old technology was fine, but Ford and every other manufacturer have gone to today's technology for reliability.
#156
#157
#158
#159
Had I been a fan of MSD, and I'm not, this would have soured me on them. A bad unit out of the box and they don't drop-ship a new one? In my old age I've become less and less tolerant of poor customer support, perhaps because time has become increasingly more precious. Now I'm even more convinced a stock ignition is the way to go.
#160
#161
Well, MSD finished up my distributor Monday the 27th and shipped it back to me. FedEx tried to deliver it today but I was not home, so I don't have it in my hands yet; They will try again tomorrow. They never called and their website is terrible - the RMA screen tells me nothing, so I still have no idea what was wrong with it or what they did to it. I'll have to get it in my possession and see if there is any documentation enclosed describing what was done. I asked them to convert it to 2-wire pickup (remove the ready-to-run stuff) if it uses the same housing and is easy to convert. We shall see...expect a report tomorrow.
#163
I got it back.
They charged me $111.55 and nowhere in the invoice does it say where they did any sort of diagnosis or trouble-shooting. I wanted to know if it was good or bad.
Oh well.
On the plus-side, they did convert it from model 8350 to model 8477 per my request. FYI...8350 is the "ready -to-run" model that I had and 8477 has a simple magnetic pick-up, which makes it easier to troubleshoot. The 8477 requires an external MSD ignition box.
The 8350 has a circuit board under it with built-in rev limiter in addition to the magnetic pick-up, and of course it also makes its own spark trigger (electronic ignition)...and since I now have the 6AL box, I viewed all that non-sense as just one more thing that can break. Additionally, having a simple magnetic pickup means that I can run DuraSpark-II if needed in the event I'm on a road-trip and need OEM parts form any auto-parts store...I could use the MSD distributor to trigger the DuraSpark, and I can also use a stock for distributor with the MSD 6AL box...so the bottom line is separate components are best for problem solving if there is an issue vs. the junk all-in-one the 8350 was.
For the fee, the entire lower shaft appears brand new and I have a new cap and rotor and I also got all my old parts back.
I know it was out of warranty, but with less than 2,000 miles on it they should have thrown me a bone in my opinion. I cannot say I am impressed with either their products or their customer service at this point. I'll let you know if it runs in a little while...
Update:
It runs great now.
Mechanical advance springs used are one heavy silver and one light silver.
I set initial timing to 10 degrees with the black bushing installed (18 degree stop) for a total of 28 degrees.
I am also running the vac advance (but 28 is still the max).
I set idle to about 800 in neutral, about 650 when in gear.
I'll post a follow-up once I get some miles on it.
Shane
Oh well.
Update:
It runs great now.
Shane
#165
