Mileage?
#46
#47
I will say, that's risky running with diesel fuel in your truck. Can anyone give me specific instructions of how to run LP with gas or CNG with gas? I was hoping to have a system, like if I ran out of CNG or LP, that the engine would switch back to regular gas. Is this a bit far fetched?
And not far fetched at all, that's what the dual fuel set-ups do, you can choose to run whichever one you want but not both at the same time. When one runs out you just flip a switch to the other tank of fuel, gasoline or LP. You have to have the engine converted to run either LP or CNG, not sure what all that entails, different injectors and computer programming maybe? Also need a fuel tank. It's not a DIY project.
Your gasoline milage might increase w/ propane injection just b/c you're not burning as much gas, but I highly doubt your overall fuel milage would increase much at all when you factor in the propane.
I'm w/ everybody else, there's just not a magic bullet to improve fuel economy in a big heavy truck. Trade it in on a diesel if you have to get 20mpg. Still have to keep your foot ouf of it though.
#48
#49
Guess it's not as easy as it used to be, seems our friends at the EPA have gotten involved. Interesting though, LP burns cleaner than unleaded fuel wonder what their hang-up is? Not enough trees to hug apparently.
Lol, that would go along well w/ DMNTBBY
#50
#51
For all the trouble you're willing to go through and the heavy loads you need to pull - biodiesel. I know somebody that bought a few transfer pumps and got his hands on some barrels and an old hot water tank. He picks up used fryer oil from the local restaurants and converts it to biodiesel. He calculates it costs him $1.35 per gallon to make and the instructions (that are proven to work) are everywhere. Never by fuel again, just get chemicals for processing biodiesel and if you can find a market for the glycerin byproduct - make a profit on biodiesel.
This stuff is legit and many people are doing it.
#52
#53
#54
Don't think it's a DIY project but here's a couple links. Good luck and let us know what you decide.
Natural Gas Conversions | CNG Conversion Kits | CNG Installation Certification Classes - CNG United
Convert to CNG
Convert to CNG
#55
Okay, so this is my plan. I get the truck, but I'm making sure I also get the CNG kit and the SCT X3 Tuner to go with the truck. I am going to install both. This way, I can possibly run to and from wherever I need to go, and when I run out of CNG, I just use the gas to get to the CNG filling spot (still unsure of where that is though, I'll dig into it sometime....). Thanks for your advice guys, especially Maverick!
#57
#58
Does that $590 include the tank? I'm sure tanks aren't cheap. Still, CNG is pretty cheap right now so it could pay for itself. Did you ever find out where the nearest filling station is? I did run across this link - apparently in California you can get a deal that lets you fill up at home using the house line. I'm guessing it must be a compressor of some sort since the house line is typically low pressure. Compressed Natural Gas (CNG) as a Transportation Fuel
#60
Power is going to be lower with the CNG conversion
More power to you but I think you are going through a lot of work for little benefit.
