My turn NO START I Found the Culprit
KR was yours a hot start issue or did it just go ? Mine has a hot start issue 190 or so cuts off doesn't start till cools down . Its still broke sitting in garage half apart.
Sean the "quote" is working now, I think....
Ya know I hauled sheetrock and made 4-5 diffrent stops not a Problem A few of the stop and starts were hot Like going threw the drivethrew and just like normal Bump the key fired right up each time yesterday No Indication of a Problem
Went out this AM and cranked it and after 5seconds of crank I knew something was Off but kept on it till 10 seconds and let off
At this Point I Pulled up ICP & IPR% & FICM Gauges and tried again
Ficm was 48volts
And ICP was way Low
Havent even messed with it yet
When I saw ICP way low and IPR% way High I knew I was toast and walked away
Gona go scan for DTC in a Min Forgot that this AM
Its blowing MACH 10 here so IDK how involved I will get today
Good thing I got the EASY ICP sensor under the Turbo
Ficm was 48volts
And ICP was way Low
AFAIK Im on the original HPOP
Im at 85K or 86K right in that range
If I do end up finding the BB Blown Out Im going to Tap it and Plug It or thats what I would Like to do in that situation
Going to go scan it for DTC see if I get any Clues
The Positive thing here is it did this in the driveway at Home
I usually dont get that lucky my luck normally would be in the Ghetto somewhere in bad part of town
Just tried again no go
SGII=NO DTC
Innova 3120 code reader=NO DTC
KOEO Readings were
ICP=0
ICPV=0.09
IPR%=14.4
Cranking this time was
ICP=170-180
ICPV=0.36volt
IPR%=77.8%
FPW=0
Didnt unplug ICP Sensor yet
OEM Oil Filter and CAP
Oil Cooler work around 13K since
You now know as much as I do (Havent even Popped the Hood Yet) Hows Everyone betting on this what do you think Taking all Bets LOL
I am going to take a stab at it and say IPR
SGII=NO DTC
KOEO Readings were
ICP=0
ICPV=0.09
IPR%=14.4
ICP=170-180
ICPV=0.36volt
IPR%=77.8%
FPW=0
Did They find any metal shavings when you had a HPO Problem??? I saw 1 truck yesterday on here that they found metal shavings in it
These Early HPOP also Blow the BB Out the HPO Pump
I praying HPOP Good
I havent noticed any Drivabilty issues as of recent
Just a No-Start this AM
