My turn NO START I Found the Culprit
#31
#32
Oh ya FTE to the rescue I wouldnt of known about the unplug ICP trick without FTE thats for shure
The SGII Pointed me in the right direction to the right Operating system
I take you didnt like me Beating up your Edge Gauge Bill sorrey Just call it the way I see as you did LOL its all good
#33
You don't have to have that tool for your model year truck. Your ICP is easy to get to on the passenger side valve cover. This tool is for the early trucks with the ICP under the turbo.
#34
Huh??? Did I read right on the ICP volts reading obtained at Key-On/Engine-Off? On a 2003 the range you should be seeing is between 0.18 to 0.24 volts at Key-On/Engine-Off. That said, your reading is WAAAYYYYYY low. If I were you, I would slam dunk an ICP and pigtail at it, for a start before you go digging deeper.
EDIT: I didn't see that there was a page 2 to this thread. Flat Rate reading.
I didnt know this either about the volts thing and ICPV at KOEO
I learned something New Thanks Mike
All I was Watching for at KOEO was IPR% and it was the 14.4%
#35
#36
So I called my local Intl dealer today out of curiosity and my ICP pigtail kit (1850712C92) is now $62.38. My ICP sensor (1845274C92) is now $104.87. My IPR (1839437C95) is now $301.40.
So I guess keep shopping around. I have seen the harness in the $50 range now and the IPR for $245 range. That's a big leap for the harness since Feb 2011 when I paid $21.
#38
Thanks for the Offer Thats a Great
My Issue is my MailLady could Screwup a WetDream I have had a Unbeleivable amount of issues with mail service the Last 6months just last week a package got return to sender For not this address Iv lived here 11years
this mail things been Bad for 5 Years but really bad last 6months
#39
#40
#41
daimlerchrysler
Had a Dakota Once Brand Spanking New first Cel Day 2 of ownership less than 30 miles 4X4 popped a Light wouldnt shift to 4x4 at the shop everyother month and Things Like steering collums ball Joints rear Main seal Fuel leval senders on and on first 2 year of owner ship I stoped a Block away from where I traded Dakota for the 6.0L craweled under it and wiped all oil from bellhousing went traded fro the 6.0L
maybe that was a bad model IDK Im not parial to any Brand just want it to go and go and it wasnt neglect on my part IDK
I had a buddey that drove the crap out a cherokee he liked it
Im just Gunshy of them now
#42
Welll ICP sensor Blew Out and Pigtail is Oil Soaked
Ford ICP was 160.00 (must be made of Gold LOL)oh ya in stock to
Colm Hooked me up with the International Dealer here in Utah They had to order it be here 2 morro but International wanted 85.00 for ICP Sensor and 12.00 shipping Fee
I can wait a day no worries be here 2morro from International
Its my BAD I thought the ICP sensor would be a Common Part in stock Next time I will Place the order Ahead of time for shure
Thanks again COLM
And everyone else thank you
Its always good to have more than 1 person look at the issue someone might take a diffrent veiw of the issue
I did start it again 2day with the ICP unplugged ICP psi was only 921 psi default value this Time it was 1800psi the other day I only let run 5-10 seconds at the most I just wanted to verify the Default ICP psi value again
Thanks again COLM
#44
