jerking in 4 wheel drive
have a 01 f250 4x4 has esof hubs. last year the 4x4 would drop out with just the hubs in auto this year in first snow would not engage unless I locked the hubs in then worked fine. have had a jerking problem if it is in 4x4 and turn steering tight with the hubs locked in and 4x4 on it does not do it if I leave the hubs locked and shut off the 4x4. Front axle shaft or drive shaft problem thanks for the help will probably get by till spring and tear the whole front end down. just looking for opinions.
If hubs aren't staying locked in Auto see if your vacuum pump is running to beat 60. If it is only when the hubs are locked you have a vacuum leak between vacuum res and axle somewhere maybe. The vents will go to defrost if this is happening. But yeah even on the beach in loose sand if I try to turn real sharp it goes to jerkin a bit. If the 3 fiddy's a jerkin don't come a lurkin.........
akuhr93'f150
04-01-2012 10:26 PM
'83f3fiddy
16
07-19-2011 01:45 PM
