What cools your engine?
With a winch, and condenser blocking my radiator, my 460 doesn't really enjoy staying cool. It runs idling at about 225, and running down the road it runs about 215. Now this is at like 96 degrees outside with 95% humidity, not optimum conditions for an engine to stay cool.
This is my current setup.
Cardone water pump
545 3 Core radiator (large radiator)
Straight 19" fan (no fan clutch)
it's all clean.
Up into the other day I had a fan shroud, but i took it loose working on something else, and it broke, but it should still be cooling while driving down the road.
So how do you all keep your engines cool? Does this sound like I have a different problem, or is my cooling system just not up to the task?
Cardone water pump
it's all clean.
on
This is my setup:
They're from a 00 Chevy Mailbu with a 3.1, simply wired through relays to a toggle on the dash for each, I usually let them both run all the time, but if the truck is idling or it is a cool day one of them keeps it plenty happy.
Stock rad, water pump of unknown vintage, 195 stat, really nothing fancy at all.
Have you checked between the condenser and the rad and made sure it's clean? I have seen in between them plugged many times. That big old mechanical fan should keep that rig cool.
I'm not losing water into the oil, I do know that much, I don't think Im losing any through the exhaust either, though it does steam for a few minutes usually when I crank it up. (Usually when its cooler).
All the water passage ways should be fine, the radiator is fairly new, and I had the motor rebuilt back during the winter so I think I have my bases covered there. Until recently, if the motor ever got hot, if I took off down the road, it would cool itself off very quickly, but I just put that a/c condenser on the front of the radiator, and bolted the winch back up, and broke the fan shroud. I know none of these help it, but I wouldn't think they would inhibit air flow traveling down the road that significantly.
I have another truck with a 460, granted it doesn't have a condenser and winch blocking the radiator, but it has a clutched fan with no fan shroud, and it'll sit there all day without running hot.
Did it run hot before putting in the new condenser? If not, then there has to be someting in those fins clogging it up so you aren't getting air flow across the radiator. blow some air from the front with an air compressor and see if you can feel it coming through the radiator. It will let you know if that is the case or not.
Received 3,178 Likes
on
Well I don't believe the fins of the condenser or radiator is the culprit, and there is absolutely no mud clogging up the fins of the radiator. And I've about decided it isn't a air flow problem because if you hold a paper towel within a foot of the grill, it'll get sucked into the abyss... As far as the timing goes, I have it timed as high as she'll go without pinging, but I have not recurved the dizzy. I set the timing with out a timing light so I don't guess I am much help with the numbers.
