Engine Oil Pressure Gauge
I'm having issues with the Engine Oil Pressure Gauge in Instrument Cluster panel. Usually happens during first startup until I run it for awhile, turn off the engine and restart, after that the gauge is fine. So, it starts in the normal, everything is good as long as I'm giving it gas, as soon as I come to a stop or slowing down the needle drops all the way to the bottom and I'll get a message taht says "Check Gauges", as soon as I give it gas the needle goes back up to normal, it never goes above normal. And like I said earlier, aftrer running for awhile I can shut the engine off, come back and start it up and the gauge is fine.
Just wondering if anyone else has seen this or knows what's going on. Thanks in advance.
It's an idiot light, the pressure switch opens between 5-7psi and reads full at any point above that; it's not accurate for more than an 'on' or 'off' answer, and only feeds a signal to the dash cluster, not the PCM. If the LPO pressure really is falling off, the truck will die from lack of oil in the HPO reservoir in about 15-30 seconds. If the truck runs normally, I'd vote the pressure switch is just acting weird and it's not a real mechanical issue. It's the sensor on the oil filter housing that has a single wire running into the connector.
Thanks guys, do you know where it's located on the 6.0's, hope it's easy.
I just had some low oil pressure work done at the Ford dealership, the truck died while driving, IPR valve was replaced along with an o-ring that went bad somewhere that was causing loss of pressure to start.
http://dan.prxy.org/Truck/6L_bible_h.../Page_025.html This is actually a view from the drivers side top.
I edited it when I was adding the pics, it took me a few minutes to track down the right book to get them partsmans link shows you exactly where it is, look for the two large black plastic caps right in the middle of the engine, then look down for a white connector with a single wire.
foreverfordtrucks
09-26-2009 06:45 PM
