Engine Oil Pressure Gauge - Ford Truck Enthusiasts Forums
Old 08-14-2012, 05:14 PM
GatorBait1996's Avatar
GatorBait1996 GatorBait1996 is offline
GatorBait1996 is starting off with a positive reputation.
I'm having issues with the Engine Oil Pressure Gauge in Instrument Cluster panel. Usually happens during first startup until I run it for awhile, turn off the engine and restart, after that the gauge is fine. So, it starts in the normal, everything is good as long as I'm giving it gas, as soon as I come to a stop or slowing down the needle drops all the way to the bottom and I'll get a message taht says "Check Gauges", as soon as I give it gas the needle goes back up to normal, it never goes above normal. And like I said earlier, aftrer running for awhile I can shut the engine off, come back and start it up and the gauge is fine.
Just wondering if anyone else has seen this or knows what's going on. Thanks in advance.
Old 08-14-2012, 05:20 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
It's an idiot light, the pressure switch opens between 5-7psi and reads full at any point above that; it's not accurate for more than an 'on' or 'off' answer, and only feeds a signal to the dash cluster, not the PCM. If the LPO pressure really is falling off, the truck will die from lack of oil in the HPO reservoir in about 15-30 seconds. If the truck runs normally, I'd vote the pressure switch is just acting weird and it's not a real mechanical issue. It's the sensor on the oil filter housing that has a single wire running into the connector.
Old 08-14-2012, 05:21 PM
BPofMD's Avatar
BPofMD BPofMD is offline
FTE MD Chapter Ldr
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
In other words, replace the pressure switch.
Old 08-14-2012, 05:38 PM
Thanks guys, do you know where it's located on the 6.0's, hope it's easy.
I just had some low oil pressure work done at the Ford dealership, the truck died while driving, IPR valve was replaced along with an o-ring that went bad somewhere that was causing loss of pressure to start.
Old 08-14-2012, 05:41 PM
Scratch that, the post refreshed when I submitted that and I saw that texastech_diesel added some EOP info. Thanks!
Old 08-14-2012, 05:42 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Standing at the front of the truck it's almost directly behind the oil filter housing. It has a one wire connector. Don't confuse it with the EOT sensor which is just to the left.
http://dan.prxy.org/Truck/6L_bible_h.../Page_025.html This is actually a view from the drivers side top.
Old 08-14-2012, 05:55 PM
Disgruntled Texan
I edited it when I was adding the pics, it took me a few minutes to track down the right book to get them partsmans link shows you exactly where it is, look for the two large black plastic caps right in the middle of the engine, then look down for a white connector with a single wire.
Oil Pressure Gauge Drops To Zero ~ChipsAhoy~ 1997 - 2003 F150 26 05-12-2016 12:30 PM
oil pump Daltongang 1987 - 1996 F150 & Larger F-Series Trucks 2 03-24-2013 04:43 PM
Oil Pressure & Water Temp Gauges in my 86 F250 with 460 are DRIVING ME CRAZY! DeadBody 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 12-30-2012 10:32 PM
Meandering Mahem! Want gauge input! Tugly 1999 - 2003 7.3L Power Stroke Diesel 6 07-22-2012 09:44 PM
Oil Pressure Problem new2bronco 1978 - 1996 Big Bronco 16 11-04-2006 10:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
