DIY Tire Rotation
good question .... i've never done it that way.
i always just drop the spare and use that to do them one at a time.
use it as a good excuse to make sure your spare is in good operating condition. My FIL found out while hunting why it is important to drop the spare once and a while to make sure that you can.
food for thought.
food for thought.
food for thought.
food for thought.
I tend to put my truck up on jack stands at all 4 corners. At the rear, I jack up the axle right under the spring packs, my jack's head fits neatly in between all 4 bolts that hold the axle to the leaf springs. I then put a jack stand under the differential tube between the pumpkin and the tires (WARNING: Ford expressly tells you not to jack up the rear end by the pumpkin, I suggest you follow this advice and jack up the rear end either at an axle tube or under the spring pack). For the front, there's a little arrow cut out of your frame rails that depicts a good spot to set down a jack stand. I jack the truck up just behind the arrow with my floor jack and then place a jack stand right where the arrow points. I proceed to swap all 4 tires and torque to 150 lb*ft of torque. Also, you'll need to re-train your sensors. After having rotated your tires and torqued them on, drive your truck around for about a mile to make sure all your tire sensors are awake. Read your owner's manual to put your truck into learning mode, you'll have to take out a little air at all 4 corners until the truck is trained, the manual does a good job documenting this procedure.
EDIT: I just called our DT and yes, they'll do it for free, even for my truck with still the OEM tires. Wow, talk about great customer service!
