Loose wires under the hood ?
I bought this truck a few weeks back so I am just learning about it.
Any guess about what these loose wires under the hood were for?
Should I connect that loose red wide to the positive pole on the battery?
Also, I am new to this forum so I don't know if I can show larger pictures here or not.
Shot at 2012-06-04
Shot at 2012-06-04
Shot at 2012-06-04
Shot at 2012-06-04
Small wires above fuse box are feedthru wiress. They're there for you to run thru the firewall. Other ends stowed in bundle above parking brake, just behind knee cover. The large red wire could have routed to an amp or inverter. I wouldn't hook that up until a through investigation.. Same with the long green and black wires.
good luck
good luck
