2004 F350 has 2 valve 5.4 with tick, need advice to fix
ok my 2004 Sd has a 2valve 5.4 that i just turned 101k last week. My motor has a tick for about three months now and i first thought it was the header gaskets. So saturday i removed the headers and install all new studs , installed new header gaskets and bolted everything back up. Well i still have this tick and the passenger side and its coming from the valve cover. So far i unpugged each injector and COP to see if its the injector of spark plug and its not any of them. So all thats lift is a lifter or the rocker? I read that you can buy a tool that pushes the valve so you can install new lifters and rocker? I also heard this is a very easy fix to install new ones? And can someone tell me if i should go OEM or aftermarket and whats a good high quality company because i dont plan to get rid of my truck. Thanks
I have very little experience with these 5.4s, but have you re-torqued all the spark plugs to make sure one is not about to blowout? My truck had a tick and I thought it was valves before I knew about the plugs blowing out on these trucks. You still may have a tick with a plug getting loose even if the COP and injector is unpluged. The helicoil kit from Snap-On was 400 bucks, but hopefully I will never do another plug blowout. I believe the torque values are 11 ft/lbs with anti-seize and 14 ft/lbs if dry. You may have already known all this, but I figured I'd mention it.
found a bad #1 plug yesterday, the porcelain seperated from the stell body and fuel/etc was blowing through it. So i installed 8 new spark plugs and my in Park tick is all gone. NOW i have a tick/thudding sound only when driving down the road? Im now thinking its a bad starter motor or a hidden rot hole in the exhaust pipe even though i cant find or see one
justplumducky
2004 - 2008 F150
11-22-2018 06:46 AM
MWH615
1999 to 2016 Super Duty
27
03-02-2010 11:32 AM
