extended front brake lines for lifted 97 F250....
Old 06-04-2012, 10:45 AM
Heavy97Duty's Avatar
Heavy97Duty
Heavy97Duty is offline
Lifted my F250 6" and need to know if anyone knows a source where to get factory style front left (driver side ) brake hose? Ordered a pair from 4 wheel parts and the driver side is not going to work unless I make a whole bunch of changes. I swapped in a Dana 60 at the same time from a 89.
Old 06-04-2012, 03:41 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Look at CROWN brake lines. Top quality
Old 06-04-2012, 05:16 PM
Heavy97Duty
ordered a set from skyjacker. Pass side is fine. Driver side not even close. on the 97 driver side the line from the master comes down and goes into the brake line, into the same brake line you have the line that goes across to the pass side. Then the hose that goes to the drive side caliper. the hose that goes to the drive side caliper has a block integral that the master line and pass side steel line all go into. i would have to make major mods to my stock stuff to make the skyjacker line even work. Crown doesnt have a listing for anything earlier then 99.
Old 06-04-2012, 06:15 PM
Diesel_Brad
That is odd. I have a pair of crown lines on my 97 and they fit just like factory.
Give them call and see what they say
Old 06-04-2012, 07:19 PM
Heavy97Duty
DB, You didnt have to modify the driver side line at all?? I will def give them a call.
Old 06-05-2012, 04:30 AM
Diesel_Brad
Nope. Went right in like it was supposed to
Jackford
07-14-2022 06:09 AM
Joeseph
10-28-2012 12:14 AM
Dancingchicken
07-03-2009 11:07 PM
Clarks1994
04-16-2008 10:07 AM
jrahn
1997-2006 Expedition & Navigator
03-10-2003 12:24 PM
Quick Reply: extended front brake lines for lifted 97 F250....
