Well im glad it was only that filter that went south. Glad its running good for you. Great job on this build. Im sure your happy Blackie is up and running and ready for RRE. Now just give it a bath, packs her up and head south.
Thanks Rob And like I said trans fuild was everywhere so I went to the pressure car wash and cleaned the underside, engine and the outside and it took about 1 1/2 hrs and $10 of quarters. I even had my own bucket with dish soap/ car wash soap and it is almost as clean as I would like it. Tomorrow clean the inside it has been sitting for 8 mths and start getting ready for RRE
Gee, a spin-on, in-line filter looks a lot better now-a-days! There goes any idea of ever using plastic filters, even on my wife's Honda!
Congratulations on your first auto-trans rebuild, Ed. Attention to detail has really paid off for you.
Pop
Thanks POP Yea I was really liking the idea of a filter with a built in magnet. But lesson learned don't use anything unless it is made of metal. I do plan on putting a spin on filter down the road. But the first thing I need to get is a gauge to keep an eye on my trans. I now will feel like I am driving naked without one. So no towing until then.
I'll report back on this tread when I get some tunes from Jody. Hopefully he help with tunes as far as balancing out the shifts. If not in about 25k when I do AFT & filter change I can adjust the the accumulator springs with the shims and I think I'll switch the 2-3 spring from the yellow to the green. 1-2 and 3-4 already have the green. But that is what Sonnax suggested as set up. There is actually a different ways to adjust the accumulator pressures now. Well I have 25k to think about it.
And as far as updates go hopefully I won't have to " No news is good news" And hopefully 50K-75k I'll be able to do the Stage2 and since I did blueprint it I'll be able to see what parts, bearing and thrust washer are wearing more than others. And hopefully I'll have the money to do a JW valve body by the time I change fuild at 25k because that alone might and will change things with my accumulator set up.
unfortunately my transmission took a dump on me too,99 ford super duty 7.3.. I really like the way you put your tranny cooler,I would like to do what you did on placing it where you put yours. can you relay me the number on where I can get that cooler
