4R100 Stage1 Rebuild
  #61
Old 07-16-2012, 11:27 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Well im glad it was only that filter that went south. Glad its running good for you. Great job on this build. Im sure your happy Blackie is up and running and ready for RRE. Now just give it a bath, packs her up and head south.
  #62
Old 07-16-2012, 11:43 PM
GonzoCSU's Avatar
GonzoCSU
GonzoCSU is offline
I was wondering when you were going to give us an update. Glad it is going well. Dang it you might make me consider doing my own trans.
  #63
Skip1970's Avatar
Skip1970
Skip1970 is offline
good job and thanks for the warning to stay away from them magnadyne filters!
  #64
Old 07-16-2012, 11:51 PM
BadDogKuzz's Avatar
BadDogKuzz
BadDogKuzz is offline
Thanks Rob And like I said trans fuild was everywhere so I went to the pressure car wash and cleaned the underside, engine and the outside and it took about 1 1/2 hrs and $10 of quarters. I even had my own bucket with dish soap/ car wash soap and it is almost as clean as I would like it. Tomorrow clean the inside it has been sitting for 8 mths and start getting ready for RRE
  #65
Old 07-17-2012, 12:14 AM
BadDogKuzz's Avatar
BadDogKuzz
After this happening you couldn't pay me to use one. They are junk !! But in theory they sound good but the piece of crap plastic housing..*&^%$#
I wonder what they are going to say when I call and complain. What they will send me a new one. No thanks "Just Say NO"
  #66
Old 07-17-2012, 12:54 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
sell it to a chevy guy if they do. they are used to tranny problems, or a dodge guy they have bad trans too.
  #67
Old 07-17-2012, 01:42 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Gee, a spin-on, in-line filter looks a lot better now-a-days! There goes any idea of ever using plastic filters, even on my wife's Honda!
Congratulations on your first auto-trans rebuild, Ed. Attention to detail has really paid off for you.
Pop
  #68
Old 07-17-2012, 09:40 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is online now
Great to hear it is working out! We want to hear back monthly updates on how it is holding up!
  #69
Old 07-17-2012, 06:16 PM
BadDogKuzz's Avatar
BadDogKuzz
Pop
Thanks POP Yea I was really liking the idea of a filter with a built in magnet. But lesson learned don't use anything unless it is made of metal. I do plan on putting a spin on filter down the road. But the first thing I need to get is a gauge to keep an eye on my trans. I now will feel like I am driving naked without one. So no towing until then.
I'll report back on this tread when I get some tunes from Jody. Hopefully he help with tunes as far as balancing out the shifts. If not in about 25k when I do AFT & filter change I can adjust the the accumulator springs with the shims and I think I'll switch the 2-3 spring from the yellow to the green. 1-2 and 3-4 already have the green. But that is what Sonnax suggested as set up. There is actually a different ways to adjust the accumulator pressures now. Well I have 25k to think about it.
And as far as updates go hopefully I won't have to " No news is good news" And hopefully 50K-75k I'll be able to do the Stage2 and since I did blueprint it I'll be able to see what parts, bearing and thrust washer are wearing more than others. And hopefully I'll have the money to do a JW valve body by the time I change fuild at 25k because that alone might and will change things with my accumulator set up.
  #70
Old 07-17-2012, 08:14 PM
SpringerPop
You don't HAVE to have the magnets "built-in".
In fact, it might be nice to see them when changing the filter to see what, if anything, has "developed".
Click on the photo for additional info.
Pop
  #71
Old 07-17-2012, 08:44 PM
BadDogKuzz's Avatar
BadDogKuzz
Pop
Very Nice write up Pop !!! The magnets are a nice touch. When I get to doing a filter set up I am going to use your write up as a template. Thank you
  #72
Old 07-18-2012, 12:39 AM
SpringerPop
Don't forget to also go look at woodnthings' write-up, too! He located it in a different place, and that might be a good alternative.
Click Here:
Pop
  #73
Old 07-18-2012, 09:53 AM
GonzoCSU's Avatar
GonzoCSU
GonzoCSU is offline
Thanks for the links Pop, good info right there
I tried doing a search on the BT111 but didn't have much luck finding the specs on it, how many micron is that filter?
I tried to see if any of the hydraulic filters we keep on hand for the tractors would work for this but they are all way too big (BT8852-MPG).
  #74
Old 07-18-2012, 03:28 PM
dieselfumes12's Avatar
dieselfumes12
dieselfumes12 is offline
unfortunately my transmission took a dump on me too,99 ford super duty 7.3.. I really like the way you put your tranny cooler,I would like to do what you did on placing it where you put yours. can you relay me the number on where I can get that cooler
  #75
Old 07-18-2012, 04:19 PM
dieselfumes12
Transmission cooler
Can I get the number for the cooler that you installed
Quick Reply: 4R100 Stage1 Rebuild
