Bad news on my new F250 *Update post 19
So I got my F250 out of the shop and they said the entire steering system needs to be replaced. They said:
Steering box
King Pins
Complete linkage assembly (tie rods, pitman arm, center link, etc)
I beam bushings
Front springs
Can anyone direct me to somewhere that I can order all of these parts and maybe help complete that list with any of the smaller things I'm going to need? They want about a grand in labor and the parts seem like they're going to be expensive too. I could do $800 on parts and do the labor myself if I have to but I can't put two grand or more into this right now.
Any help would be GREATLY appreciated.
Am I going to need all of this? Any donor trucks I should check the scrap yards for? Bronco's?
Steering box
King Pins
I beam bushings
Front springs
I feel like a fool asking this, but I can't seem to find an "I beam" or "I beam bushing" in the LMC catalog anywhere. Is there another name I should be looking for that it is called?
If your suspension and steering are original there is no doubt that all of that should be replaced. Except maybe springs.
You are going to get into some very heavy labor with the things you describe. King pins alone will wreck a Saturday morning. And you will need special tools.
Suspension work is no joke.
$2k does not sound bad at all for all that work. I live in Bay Area CA and no shop would touch that extensive work for that money.
It all depends on what your plans are for the truck. My advice: Don't mess with that work yourself.
Is it really that big of a job? I have the time and can spend a few weeks on it if necessary. I'm no expert but I am pretty mechanically inclined and patient. I don't mind buying the tools either. That's pretty much why I made this thread.
What special tools am I going to need that you can think of?
the only special tools I can think of is a tie rod/pitman arm separator, maybe a spring compressor, and torque wrench.
Kingpins range from $70 to $90 plus shop labor to ream and fit the metal bushings. Mine ran $90. The big dollar item is the steering box... $220 from your local Autozone but a quality unit from Red-Head or Bench Works is about $400.
Take what your shop states with a grain of salt. Some merely make it seem worse than reality to milk more manhours out of ya. Do your own inspection.
Leave the machine shop stuff to the machine shop. Otherwise, a decent set of tools will save lots of money if you do it yourself. Think about it... it's just an assemblage of components that a high school graduate (maybe) put together on the assembly line.... It's not rocket science.
Atta boy.. you CAN do it.
Go to the bottom of this link for a list of vendors : https://www.ford-trucks.com/forums/1...l#post13139591
Btw, Rock Auto is a really good source for replacement parts. Personally, I prefer Moog steering & suspension components. Try to avoid the imported stuff.
Edit: I found this link in your link and it's exactly what I needed. I'm just going to do all of it and take the kingpins down to the machine shop to have the old pins pushed out and the new bushings pressed in and reamed. I think I'm actually looking forward to this. I'll be able to paint a lot of my suspension while I do it.
You will very likely wind up having to remove the I-beams and take them and the spindles to a shop to have the old king pins pressed out. They can be EXTREMELY difficult to remove without a heavy duty shop press. The shop will install the new bronze bushings into the spindles and ream them to size. Take one of the new king pins in with you as they'll need that to get the size correct.
This would be an excellent time to replace the suspension bushings as well. I used Prothane bushings I bought from Amazon, but many vendors sell them.
Prothane 6-1207 Red Radius Arm Bushing Kit and Prothane 6-604 Red Axle Pivot Bushing Kit with Twin I-Beam are the ones you'll need. The king pin set you need may be different from mine, though. I have a camper special.
I can't help much with the steering box. I didn't replace that. Last fall, I replaced the king pins and suspension bushings on Frodo. Here's a write up I did on it:
The FORDification.com Forums • View topic - Frodo, the '69 F250 CS
It really wasn't that bad a job to do. You can handle it. You will need to take your truck in for an alignment when you're done.
Good luck!!
Good luck!!
Chris, all good advice above. But you have not said that you have a problem with the steering except what the shop guy said.
The shop guy sells steering and suspension.
Why don't you crawl under the front end and have wifey wiggle the steering wheel back and forth? Look for loose in the steering knuckles and bushings. Jack up the truck and have wifey wiggle the tire to see how bad the flop is in the kingpins.
As Jowilker, I am suspicious of the advice from the shop.
Good luck!!
Good luck!!
I'm going to check out everything this weekend but I took a little while last night and looked and the tie rods don't seem loose or anything although a lot of the bushings look like they need to be replaced. The front coils are pretty bad too. It's looks like I'm going to replace the rag joint, radius arm bushings, I beam bushings, king pins, and front coils. I'm hoping that takes care of everything because otherwise I'm going to be pissed if I have to rip it all apart again! All of those parts plus machining for the king pin bushings puts me right at my budget so thank you everyone that gave advice here. I'll update once I do the work next weekend.
Do not go by these descriptions, because LMC (as usual) hasn't a single clue!
Look at Ford truck parts catalog pic.
3280 includes 3A131 left outer tie rod, 3281 sleeve and 3A130 tie rod end. These 3 parts also available individually.
Disregard LMC's wild mule p!ss inre to the before/from serial number M00,001 center link, because this only applies only to the 3304 draglink.
