Oil Leak from HPOP fitting
Old 05-31-2012, 09:31 AM
Talyn's Avatar
Talyn
Talyn is offline
Yeah, dont use crappy o-rings.
This is the same leak I had for 2 years and Never knew where it was coming from till I pulled my pump and found one of the fittings loose.
Old 05-31-2012, 09:35 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Old 05-31-2012, 11:17 AM
fordpride's Avatar
fordpride
fordpride is offline
The OBS doesn't have the quick connect line like the SD so you don't need the tool
Old 05-31-2012, 11:47 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Smile
I also had a oil leak some time ago from the o-ring in one of the HPOP fittings https://www.ford-trucks.com/forums/1...vice-asap.html
Old 05-31-2012, 12:59 PM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
Thanks for all the info guys. I got in touch with Joey at Terminator as well and got the same answers. New -6 o-ring should fix it.
Old 05-31-2012, 01:41 PM
Talyn's Avatar
Talyn
Talyn is offline
Having the right o-ring for the index and crush is important.
Mine was just loose in general, but had the wrong o-ring from the P/O.
No leaks now. =)
Old 05-31-2012, 02:28 PM
CampSpringsJohn
Make sure the fitting is clean and dry, and a dab of loctite on the threads. Ford sends 680 with their kit, as does Guzzle.
Old 05-31-2012, 02:45 PM
Brown Falcon
Ordered the kit from Riffraff, comes with all 7 o-rings for the HPOP and the loctite for it, all for under $13
Old 05-31-2012, 07:53 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I got a kit from Bob when I ordered a dipstick repair kit. Its in my tool box for 'just in case'.
IIRC Jose, you were on a trip when it happened to you.
Old 05-31-2012, 08:08 PM
Brown Falcon
I still plan to get a T500 and new lines as soon as I can sell my 2wd trans...
No interest on craigslist yet...
Old 06-01-2012, 09:40 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Yes sir, was almost a nightmare, but with the help of the people in this forum I figured out with happy end.
Old 06-01-2012, 02:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Smile
Here is the culprit and the new one. and when I changed, in the second pic is as my face looked ( ) LOL.
  #28
Old 06-01-2012, 03:55 PM
Brown Falcon
Haha, nice Jose!
  #29
Old 06-01-2012, 08:05 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Dang. That o-ring was in bad shape!!! lol
  #30
Old 06-01-2012, 08:46 PM
Talyn's Avatar
Talyn
Talyn is offline
I think Jose showed us his O-face....
Quick Reply: Oil Leak from HPOP fitting
