Damn V-10's
Old 05-30-2012, 03:39 PM
MrThinroyy's Avatar
MrThinroyy
MrThinroyy is offline
Damn V-10's
Well I have a 2000 Ford excursion with the 6.8L in it, only 148,000 miles on it, and I'm having a bit of a problem: she's misfiring. Bad. It started at around 147,250, and it's been going on ever since. She had the platinums in for the spark plugs, and I've replaced both the fuel and air filter, and 8/10 spark plugs (it was late and I didn't wanna work on 4&5 any longer), but I've taken it to multiple auto shops and had them plug the computer in, no readings, codes, nothing. Besides those last 2 spark plugs, is there anything else that could cause the misfire? It's not like she has a lot of miles on it, from what I've read the V-10's have one of the rest lifespans besides diesels, even if their MPG is pathetic.
Old 05-30-2012, 03:43 PM
TrdLtly's Avatar
TrdLtly
TrdLtly is offline
TreadLightly
COP's, COP boots, COP plugs, COP harness, injectors, injector orings, bent valves, valve seats, rocker arms.... that is all I can think of for now.
Old 05-30-2012, 03:53 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
It's always those dang Cops! You'll get better and better at checking them over time - especially No. 5.
Old 05-30-2012, 09:46 PM
Keving150's Avatar
Keving150
Keving150 is offline
My 2001 V-10 developed a miss the end of last summer. Replaced all 10 plugs, boots, PCV and #4&5 COP with no luck. Finally gave my Mass air flow sensor and throttle body a good cleaning and that did the trick.
Old 05-30-2012, 09:51 PM
EXv10's Avatar
EXv10
EXv10 is offline
Do the whole job and get back to us........................10!
Old 05-30-2012, 09:52 PM
MrThinroyy's Avatar
MrThinroyy
I do know a bit about trucks but the shorthand gets me, what are COPs?
And thanks kev, I'll give that a shot this weekend
Old 05-30-2012, 09:55 PM
Keving150's Avatar
Keving150
COP= Coil On Plug
Good luck
Old 05-30-2012, 10:02 PM
MrThinroyy's Avatar
MrThinroyy
I've already replaced the coils and boots, plugs, and harnesses. I'll check out the Mass Air Flow Sensor like keving said, then if she's still sputtering I'll look into the injectors, rocker arms, etc. Thanks everyone, hopefully I'll get her back up to full steam soon.
Old 05-30-2012, 10:57 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
i'm going to say coils. i've had brand new ones be bad. finally spent the big bucks on motorcraft coils last time after fighting a miss issue since i had bought my ex.. that was in march, no issues since!
Old 05-31-2012, 09:09 AM
EXv10's Avatar
EXv10
EXv10 is offline
Those guys in the rear view mirror when you are speeding...............or the little coils for every cylinder.
Old 05-31-2012, 01:52 PM
fatherdano's Avatar
fatherdano
fatherdano is offline
+1 new ones can be bad.
is your check engine light working?
Old 05-31-2012, 02:00 PM
MrThinroyy's Avatar
MrThinroyy
Yeah the light works but it's not on, like I said, I've actually gone to the shops and they plugged it into the computer and nothing came up.
Old 05-31-2012, 02:26 PM
fatherdano's Avatar
fatherdano
then that needs fixing too. if your misfiring and its not registring seems odd?
Old 05-31-2012, 02:36 PM
MrThinroyy's Avatar
MrThinroyy
Yeah it does seem odd, which is why I'm wondering what's going on. The check engine light isn't on, and the computers don't read anything. It's irritating.
Old 05-31-2012, 06:22 PM
shadows4's Avatar
shadows4
shadows4 is offline
COP's- Coil on Plug. Buy a good one and move it around till you find the bad one. Start by replacing the two plugs you neglected to do. Good luck and keep us informed.
Quick Reply: Damn V-10's
